jme wrote:
Thanks for the quick reply.
I actually have both torque steer and bump steer.
I have not driven a front wheel drive with an ATB diff, is torque steer normal for these?
I really like the ride of the hydro so I'd rather not get rid of it.
yeah i think you`ll find that once you get rid of the pitching & diving that you`ll have reduced the toe changes ,,, with all the ride-height changing as you accelerate & decelerate, the toe changes dramatically because of it & coupled to the steering rack positioning,,, makes for quite a bit of bump steer (which is mostly what you`re getting when accelerating) Toreque steer would be very slight indeed (as with most minis with fair power
if you had ,,, say,,, over 100hp & some terribly offset rims & real tight LSD etc etc etc,,, then maybe there`d be an argument for excessive torque steer to banter about with
but if you have (as you say) a Quaife type diff & mild road mini power,,, then my suggestion would be that you have more of a bump steer problem simply caused by the dramatic change in toe setting during all the excessive ride height changes that your car is going through
bump steer is effective simply upon suspension travel movement,,, not just hitting a bump
if you corner , then the suspension on one side squats & the other side droops,,, you have now got changes in ride height which has influenced the bump-steer,,, a simple geometry problem inherent in most minis
my race buggy (for example) i have kept it fairly soft in suspension as there is little weight ,,, but it still moves about because it`s fairly soft so you`d think i`d have some bump steer too right?
but it has almost Zero bump steer,,, no mater what you do with suspension travel it just remains fairly true with it`s toe
Good ey?
& that`s because i positioned the steering rack to where it was at it`s best to suit the ride height & suspension arm geometry, effectively placing the rack ball-ends in the right spots
Like i said earlier--->
if there`s no play in there Anywhere,,, no loose steering arms???... no rack play???... No worn/sloppy bushes???... no loose steering rack mounting u-bolts???...etc
then i`d look at trying to reduce the excessive suspension travel (pitching & diving) before you do anything,,, sounds like your hydro bags are pretty stuffed ... & maybe those spax may not be doing much either by the sounds of it???
Normally Spax are horribly stiff things for road cars ,,, ah well,,, sorry i can`t help much more than that... once you fix your main problem with the pitching & diving--> i feel you will find very little torque steer left to "torque" about
