TDC not on 1/4 flywheel marks https://www.ausmini.com/forums/viewtopic.php?f=2&t=80786 |
Author: | spfh84 [ Wed Mar 20, 2013 9:26 am ] |
Post subject: | TDC not on 1/4 flywheel marks |
Hi all,, this one has me stumped again (seems to be happening a lot lately)...went to install the distributor drive and was setting TDC on firing stroke on no 1 piston...found TDC with the piston and checked on the flywheel and the 1/4 mark is nowhere to be seen... rotated the engine until I lined it up and the piston is well and truly on its firing stroke. How can this be?!?!?!?! Thanks |
Author: | drmini in aust [ Wed Mar 20, 2013 9:28 am ] |
If it's a 2 piece flywheel, the outer part can bolt onto the hub in 6 positions. Only 1 is correct. Obviously someone has had it apart. I don't use those marks they are a PITA. I weld a pointer to the timing cover (or use a later cover), then file a TDC mark on the pulley. |
Author: | spfh84 [ Wed Mar 20, 2013 9:38 am ] |
ok. Is it worth fixing while I have access to it? |
Author: | drmini in aust [ Wed Mar 20, 2013 9:40 am ] |
Sure, if it's out of the car... ![]() When you retighten the 6 nuts (to ~38 ft/lb) centre pop them again in 3 spots so they can't come loose. |
Author: | spfh84 [ Wed Mar 20, 2013 9:47 am ] |
thanks again for your wisdom doc! seeing as it was balanced the way it is now will moving it around affect much? |
Author: | drmini in aust [ Wed Mar 20, 2013 10:59 am ] |
Nope it shouldn't really change balance, as the hub is steel and machined true all over. Unlike the outer bit which is grey cast iron- that varies in density. |
Author: | mickmini [ Thu Mar 21, 2013 11:14 am ] |
i would just buy a new steel flywheel from the UK (i did!) far easier and no (little) chance of it being out of balance. |
