Air intake grill early Cooper heater https://www.ausmini.com/forums/viewtopic.php?f=2&t=80795 |
Page 1 of 3 |
Author: | haze blue 850 [ Wed Mar 20, 2013 9:32 pm ] |
Post subject: | Air intake grill early Cooper heater |
Greetings All. Sorting parts for the wifes project. Refurbishing heater for under dash. Had a few questions: Has anyone got a picture (s) of the little mesh/grill at the end of the fresh air hose (about 4-1/4"diameter) which sits behind the grill. Can't find a part number. Haven't seen one at Mini events. No idea what it looks like. Would replicate one if I had some front n back pic's. Also, where to source the 4-1/4" hose from heater to grill (how long??) and the 1-1/4" hose to dash demist vents? The heater is the one with a chrome toggle switch, and the lever you lift for airflow direction. Cheers Alex |
Author: | TheMiniMan [ Wed Mar 20, 2013 10:27 pm ] |
i have a few 2nd hand ones here Matt 0407 135 656 |
Author: | wild_willy [ Wed Mar 20, 2013 10:30 pm ] |
Purple Pig here in Bayswater Melbourne has a very good quality tubing which is close to the original rubber over wire tubing. The air inlet at the grill is a basic device which the tube attaches to with a coarse mesh. ![]() This pic is of a later plastic version normally metal ![]() |
Author: | haze blue 850 [ Thu Mar 21, 2013 6:32 am ] |
Thanks gentlemen. About to go to work. Will follow-up. Cheers Alex. |
Author: | haze blue 850 [ Thu Mar 21, 2013 7:44 pm ] |
Matt. Rang this afternoon, but rang out. I'll PM you about vent grill. Wild willy. Have contacted Purple Pig to get the large hose. Thanks. Alex. |
Author: | Monaco [ Thu Mar 21, 2013 8:24 pm ] |
You can buy them new again if you want a repo one! |
Author: | miniron [ Sun Mar 24, 2013 9:43 pm ] |
The original metal one is similar to wild willy's plastic pic. IIRC the hose is 3 1/4 " not 4 1/4" dia. While on this subject does anybody know if the the large rubber grommet that fits the bulkhead hole the air hose goes through is still available. I've been looking on and off for a long time trying to locate one. My S has the black cover plate over the hole and I'd like to convert the heater to have a fresh air intake. I did this on a 66 S I had 45+ years ago but all the parts were readily available then. RonR |
Author: | Mick [ Sun Mar 24, 2013 10:06 pm ] |
Yep, surf is. Will have to wait till tomorrow to get you the link. It's from the uk. |
Author: | Mick [ Mon Mar 25, 2013 6:49 pm ] |
Here you go Ron, I hope this is the right one. http://www.totalrepellents.co.uk/minibi ... rubber.htm ![]() |
Author: | haze blue 850 [ Mon Mar 25, 2013 8:29 pm ] |
RonR. The heater I have has a PVC fitting to take a 102mm (4-1/8") air hose. I also need the demister hose bits. Purple Pig in melbourne still haven't replied with availability. Clarks Rubber can get it in if required $65 per metre, which I thought was fair. Alex. |
Author: | TheMiniMan [ Mon Mar 25, 2013 9:13 pm ] |
ok, sorry for the delay to those who have PM`d me, i went surfing ![]() i`ll tak a pick of the vent tomorow & post it here BUt..... i`m afraid that it will have to be a case of first in best dressed cause i`ve had a few of you PM me & no one has bitten the bullet yet so i`ll post a pic or 2 of it & see what happens,,, or would you rather me list it on ebay & you can all fight it out fair & square??? & sorry i thought i had a couple of them but Archie got one off me for his wagon a while ago & now i only have the one left & yes it`s in really good condition |
Author: | Panthersteve [ Mon Mar 25, 2013 9:25 pm ] |
I think I have a spare if that will ease the fighting ![]() |
Author: | wild_willy [ Mon Mar 25, 2013 10:30 pm ] |
miniron wrote: The original metal one is similar to wild willy's plastic pic. IIRC the hose is 3 1/4 " not 4 1/4" dia.
While on this subject does anybody know if the the large rubber grommet that fits the bulkhead hole the air hose goes through is still available. I've been looking on and off for a long time trying to locate one. My S has the black cover plate over the hole and I'd like to convert the heater to have a fresh air intake. I did this on a 66 S I had 45+ years ago but all the parts were readily available then. RonR Somerford Mini UK 28 24A2195 GROMMET, hose through dash 1 |
Author: | TheMiniMan [ Tue Mar 26, 2013 4:05 pm ] |
![]() ![]() it`s actually better looking than the pics suggest i will grade this item as being in Very good condition cheers Matt edit--> Oh & it`s actually from a march 1963 cooper |
Author: | haze blue 850 [ Tue Mar 26, 2013 5:17 pm ] |
Matt. How much ya wanting. Alex. |
Page 1 of 3 | All times are UTC + 10 hours |
