It is currently Sun Jul 27, 2025 1:27 pm
 Post subject: Moke Windscreen Wipers
PostPosted: Thu Mar 21, 2013 10:00 pm
Die Die Die!!
is it possible to use a steering column stalk wiper switch instead of the dash mounted knob on a moke to operate the window wipers ?
Nick
PostPosted: Thu Mar 21, 2013 10:45 pm
You mean something like this ?
http://www.minisport.com.au/prod1125.htm
PostPosted: Thu Mar 21, 2013 11:39 pm
Die Die Die!!
Yes.. Can that be used as a substitute for the 6pin knob switch usually in the dash ?
PostPosted: Thu Mar 21, 2013 11:46 pm
yes you can use that stalk. make sure you hook the brake wire from the wiper motor correctly else it may not park properly.
i just fitted a rover steering column to an 81 moke. was a ning nong to get the brake working properly on the wiper motor.
- '74 Clubman Ute project
PostPosted: Fri Mar 22, 2013 12:13 am
Die Die Die!!
I'd like to fit the same, but at the least dual stalks
PostPosted: Fri Mar 22, 2013 4:22 am
Not as easy as it looks. The pre-1980 column is too big in diameter. You can change columns too, but the lower mount is in the wrong place, so you'll also need to change the pedal box.
To make the Moke wiper motor park with that wiper switch, you need to modify the wiper motor.
PostPosted: Fri Mar 22, 2013 6:24 am
Die Die Die!!
Sounds difficult, ill just stick to the original stalks and columns
