installing horn on rover mini https://www.ausmini.com/forums/viewtopic.php?f=2&t=80812 |
Author: | nixphotopix [ Fri Mar 22, 2013 4:49 pm ] |
Post subject: | installing horn on rover mini |
Just purchased a cheap AAH-OOH-GAH horn for my mini. Came with zero instructions on how to install it also. Says its for 12V 3A power so hope this will work. Has a red and black pos and neg cable and one nut and bolt. So first question. Where do I wire it to and were do I mount it? Has anyone installed one of these ebay horns? Will prob try on weekend but would like some advise before. cheers, btw its for 98 rover cooper |
Author: | Harley [ Fri Mar 22, 2013 4:51 pm ] |
Take the existing horn out, cut the plug off the end and crimp on new suitable insulated spade terminals. I think purple wire is positive. Mount the horn anywhere you can - your engine bay is pretty full. ![]() |
Author: | danny_ [ Fri Mar 22, 2013 5:22 pm ] |
Harley wrote: Take the existing horn out, cut the plug off the end and crimp on new suitable insulated spade terminals. I think purple wire is positive.
Mount the horn anywhere you can - your engine bay is pretty full. ![]() I mounted mine on my old 93 rover mini in the drivers side guard.. After i ripped the aircon out. No space in my 97 rover but i have a Klaxon waiting to go in the moke. |
Author: | Harley [ Fri Mar 22, 2013 5:28 pm ] |
Plenty of room in a 97 - I've got twin magnums in there. ![]() |
Author: | Convertible Mini [ Fri Mar 22, 2013 8:28 pm ] |
Post subject: | Fitting Horn on Rover. |
Or if you want to do it properly use the existing horn wires to trigger a Relay. Feed the relay a decent 12 volt supply (Fused) and take the horn power from the relay it will work better and will not melt your horn switch. |
Author: | Harley [ Fri Mar 22, 2013 8:45 pm ] |
98 model minis were like that from factory. ![]() |
