It is currently Mon Jul 21, 2025 3:18 am
 Post subject: Printed circuits?
PostPosted: Sun Mar 24, 2013 4:14 pm
Hey again, been having a busy weekend on the mini, thanks for the help so far. next up i am looking at replacing the printed circuit on the back of the gauges, i have pulled it out but it doesnt seem to match any of the ones on minisport. could someone please help identify which one i have and/or which one i need.
the one i have
the front so you know which gauges i have (its upside down to keep the gauges on the correct side)
the minisport one that is closest one i could find
http://www.minisport.com.au/prod1794.htm
it seems to be about 80% right except for the bit on the left around the tacho. any help would be much appreciated.
 Post subject: Flex Printed circuits.
PostPosted: Sun Mar 24, 2013 5:06 pm
I now also have these correct Printed circuits for these Clusters which are also used on Clubman GT.. PM sent.
"Let us remove your "SHORTS"
PostPosted: Sun Mar 24, 2013 7:38 pm
The PCB looks to be in good condition...why change it??? :D
PostPosted: Sun Mar 24, 2013 8:40 pm
It's hard to see in the photo but the section between the tachometer and fuel/temp gauges ( top left in photo ) has been bent to many times and has broken the connections
PostPosted: Sun Mar 24, 2013 10:05 pm
Ohh? OK....but you can just gently remove the conformal coating and solder (using say some multi=strand braid or wire) then spray or paint with a protective coating :idea:
