Printed circuits? https://www.ausmini.com/forums/viewtopic.php?f=2&t=80828 |
Author: | Paddy [ Sun Mar 24, 2013 4:14 pm ] |
Post subject: | Printed circuits? |
Hey again, been having a busy weekend on the mini, thanks for the help so far. next up i am looking at replacing the printed circuit on the back of the gauges, i have pulled it out but it doesnt seem to match any of the ones on minisport. could someone please help identify which one i have and/or which one i need. the one i have ![]() the front so you know which gauges i have (its upside down to keep the gauges on the correct side) ![]() the minisport one that is closest one i could find http://www.minisport.com.au/prod1794.htm it seems to be about 80% right except for the bit on the left around the tacho. any help would be much appreciated. |
Author: | Convertible Mini [ Sun Mar 24, 2013 5:06 pm ] |
Post subject: | Flex Printed circuits. |
I now also have these correct Printed circuits for these Clusters which are also used on Clubman GT.. PM sent. |
Author: | 9YaTaH [ Sun Mar 24, 2013 7:38 pm ] |
The PCB looks to be in good condition...why change it??? ![]() |
Author: | Paddy [ Sun Mar 24, 2013 8:40 pm ] |
It's hard to see in the photo but the section between the tachometer and fuel/temp gauges ( top left in photo ) has been bent to many times and has broken the connections |
Author: | 9YaTaH [ Sun Mar 24, 2013 10:05 pm ] |
Paddy wrote: It's hard to see in the photo but the section between the tachometer and fuel/temp gauges ( top left in photo ) has been bent to many times and has broken the connections
Ohh? OK....but you can just gently remove the conformal coating and solder (using say some multi=strand braid or wire) then spray or paint with a protective coating ![]() |
