wind up doors on an 850 https://www.ausmini.com/forums/viewtopic.php?f=2&t=80838 |
Author: | junior [ Mon Mar 25, 2013 4:25 pm ] |
Post subject: | wind up doors on an 850 |
Will wind up window doors from a deluxe fit in a 850 shell? Can't recall if I read the locks & B pillar were different, or is that only for a clubby |
Author: | Harley [ Mon Mar 25, 2013 4:52 pm ] |
It'll fit, won't be perfect but will work. |
Author: | TheMiniMan [ Mon Mar 25, 2013 5:03 pm ] |
swap over the nylon buffer with the metal cup, or vice versa |
Author: | drmini in aust [ Mon Mar 25, 2013 5:25 pm ] |
Use windup & later door rubbers (wider) not the 850 ones. |
Author: | John Smidt [ Mon Mar 25, 2013 6:00 pm ] |
On the 850 the nylon is on the door and the metal cup is on the Body, On the deluxe the metal cup is on the door and the nylon is on The body, Take note The cups and the nylon on the deluxe are larger than the ones fitted to the 850 If You have a good set of sliding window doors do not throw them out |
Author: | 69k1100 [ Mon Mar 25, 2013 6:12 pm ] |
Or do throw them out, just let us know where you dump them! |
