torque setting for flywheel and crank
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80841
Author:  my1293 [ Tue Mar 26, 2013 1:16 am ]
Post subject:  torque setting for flywheel and crank
hi all im rebuilding my motor with my next door neighbor hes a old school motor mechanic. anyway we are upto the stage where we are torquing up the flywheel cover and end of the crank
he seems to think that he knows it by his own arm is this possible ?
and should i trust him on this?
now my question is
1. what are the torque settings for the 3 bolt holding he cover , flywheel and clutch plate?
2. torque setting end crank nut
cheers for looking
Author:  GT mowog [ Tue Mar 26, 2013 6:19 am ]
1. 16 ft / lbs
2. 110 - 115 ft / lbs is what the factory recommend, however I'd suggest 150 ft / lbs.
Author:  drmini in aust [ Tue Mar 26, 2013 7:06 am ]
GT mowog wrote:
1. 16 ft / lbs
The good book says only 70lb/ft for the crank pulley bolt.
I use 75-80 on the crank pulley and 130 on the flywheel centre bolt, Loctite 262 on both, and NO cheesy aftermarket lock tabs...
[edit] I do the diaphragm to backplate bolts to 18 lb/ft. I Loctite these too.
Author:  my1293 [ Tue Mar 26, 2013 11:41 am ]
Post subject:  thank u
thank u sir
Author:  peterb [ Tue Mar 26, 2013 6:19 pm ]
The big bolt is F'nT and the little ones ....not that tight :lol:
