It is currently Sun Jul 20, 2025 7:57 am
 Post subject: Fitting Top arms
PostPosted: Wed Mar 27, 2013 1:20 pm
Die Die Die!!
when fitting the top arms into sub frames the large washer should sit inside the sub frame recess right ?
also should go as follows
nut, spring washer, retaining plate, large washer, on the engine side
spring washer and nut on the firewall side ?
PostPosted: Wed Mar 27, 2013 7:31 pm
Sounds right to me
If its yours, customize it !
 Post subject: Re: Fitting Top arms
PostPosted: Wed Mar 27, 2013 8:48 pm
[quote="_666_"]when fitting the top arms into sub frames the large washer should sit inside the sub frame recess right ?
Dont forget the other thrust washer on the firewall side! Oh, and also the rubber dust seals which fit over both thrust washers.
PostPosted: Wed Mar 27, 2013 9:08 pm
Die Die Die!!
forgot to mention those but I had them on there
I just wasn't sure why the large washer wasn't sitting inside the subframe recess, I think the powder coating must have made it slightly thick, ill sand a bit back so it fits inside
Users browsing this forum: No registered users and 68 guests
