Fitting Top arms
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80852
Author:  _666_ [ Wed Mar 27, 2013 1:20 pm ]
Post subject:  Fitting Top arms
when fitting the top arms into sub frames the large washer should sit inside the sub frame recess right ?
also should go as follows
nut, spring washer, retaining plate, large washer, on the engine side
spring washer and nut on the firewall side ?
Author:  1380 K [ Wed Mar 27, 2013 7:31 pm ]
Sounds right to me
Author:  wild_willy [ Wed Mar 27, 2013 8:48 pm ]
Post subject:  Re: Fitting Top arms
[quote="_666_"]when fitting the top arms into sub frames the large washer should sit inside the sub frame recess right ?
Dont forget the other thrust washer on the firewall side! Oh, and also the rubber dust seals which fit over both thrust washers.
Author:  _666_ [ Wed Mar 27, 2013 9:08 pm ]
forgot to mention those but I had them on there
I just wasn't sure why the large washer wasn't sitting inside the subframe recess, I think the powder coating must have made it slightly thick, ill sand a bit back so it fits inside
