battery puzzle
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80901
Author:  aussie [ Sat Mar 30, 2013 4:08 pm ]
Post subject:  battery puzzle
So I can quite happily drive for an hour+ with high beams and stereo going. park the car, come back and start it up straight away.
But sometimes my battery just dies. i.e. Go to turn the key and get very little or even nothing (so I jump start), and off I go.
I assumed the alternator was okay and this was a battery issue, so I put in a spare battery which I charged up overnight but it also died.
Have I been playing with 2 dead batteries? Or are these symptoms of something else not working properly?
Author:  Wombat [ Sat Mar 30, 2013 4:18 pm ]
Check all connections - particularly the earth straps. Undo clean all surfaces and retighten.
Author:  Goldbrocade_62 [ Sat Mar 30, 2013 6:19 pm ]
My mated used to go flat after it sat a while something in the new stereo was draining the battery
Author:  Convertible Mini [ Sat Mar 30, 2013 7:47 pm ]
Post subject:  Battery going flat.
It sounds like it is time to get things professionally tested and checked and cut out the guessing.
Author:  winabbey [ Sat Mar 30, 2013 7:59 pm ]
I agree based on what you have described.
Check if the battery is really flat when you try to re-start it or just not making a good connection up to the starter motor which makes it appear to be flat. If you have a battery charger or some other device for checking battery condition use it on the battery terminals themselves when you get the 'flat battery' condition.
After you jump-start, immediately turn off the ignition and try starting in the normal way without the auxiliary battery. If it starts as normal it almost proves a bad connection somewhere and not a flat battery.
Author:  Davo111 [ Sat Mar 30, 2013 10:40 pm ]
Mine had the same so I just brought a new battery and problem solved;-);-)
Author:  peterb [ Sun Mar 31, 2013 8:14 am ]
when it goes 'dead', check power with multimeter while someones trying to start it. Start at battery, the live side of soliniod, starter side, then bolt on starter. See were power stops. A multimeter is cheap and you can use it for other things.
Author:  MiniVLT [ Sun Mar 31, 2013 10:11 am ]
Battery terminal "scale" is a common problem with any starting issues!
Clean up the battery terminals & connections first.
Cheers Shane
Author:  frednutz&co [ Sun Mar 31, 2013 12:11 pm ]
check the terminals on the solenoid also when we picked up latest van one of them was corroded .replaced it and started of the "flat "battery. :D
