Ramair filters for Weber
https://www.ausmini.com/forums/viewtopic.php?f=2&t=80909
Author:  Cooper_Matrikon [ Sun Mar 31, 2013 5:37 pm ]
Post subject:  Ramair filters for Weber
Anyone had any experience with these?
http://ramair-filters.co.uk/rs-carb-filters/weber-40-dcoe-carb-air-filter-with-baseplate.html
Wondering if they may be a space saver and if so with what ram tubes? Any pics?
Author:  Cooper_Matrikon [ Mon Apr 15, 2013 9:32 am ]
No one running these?
Author:  drmini in aust [ Mon Apr 15, 2013 10:15 am ]
I had a look at that link.
As you don't have a Weber box in the firewall you will be stuck with using a short one. It won't have as much surface area as a Lynx Ramflo would, this might choke it.
Lillee tried to run a short K&N on his 45 Dellorto (with a small Weber box) and that's what happened, so he used Unifilter socks instead.
Personally I think with a stock firewall and a Weber + Redline 3005 manifold (or equivalent), a Lynx Ramflo RF445P5 with a Unifilter foam pad is hard to beat.
Author:  Lillee [ Mon Apr 15, 2013 10:46 am ]
I read this post earlier but refrained from commenting as I personally haven't used this particular filter before (one of only a few that I haven't tried!).
Basically you run it with a backplate on and use some extremely short ram tubes such as these:
http://www.dellorto.co.uk/merchandise/p ... ctionID=41
The issue is that the foam literally sits on top of the ram tube with no clearance (flush against the mouth of the ram tube) and this is essentially like stuffing a cloth over the intake of your Weber. For ram tubes of any sort to work they need some clearance around the front and the mouth of the ram tube.
I agree though, without a weber box, there isn't much choice at all. Hence why I made the (excruciating) decision to weld in a box and never looked back...
EDIT: you can try one thing, install the short ram tubes as above and pop one of these over it:
http://www.dellorto.co.uk/merchandise/p ... ctionID=64
Basically it's just a hollow foam "cage" over the top of the ram tubes. Yes it will be a squeeze in some bits, especially the bottom, but at least it will be open and unobstructed sides and above. This MAY be slightly less restrictive than all other options? FYI this is what I run
