It is currently Wed Jul 30, 2025 12:10 pm
PostPosted: Mon Apr 01, 2013 6:39 pm
Hi guys.
Took to pulling the car down today for a bit of a gearbox refresh, and unfortunately found that the outrigger bearing (in this case, part no. ADU6033) outer journal is loose in the transfer case. There is early evidence of some rotation - nothing to worry me, but I do want to make it stay put.
What are the options?
The only thing I come up with is Loctite 601, but will it like a permanent oil bath, and what happens when it comes time to replace it - hard enough getting the darned things out, much less when they've been 'tited in!
Thanks for advice!
'68 Deluxe w/Metro engine
PostPosted: Mon Apr 01, 2013 7:19 pm
I can't think how it happened, but I believe its time for a new transfer case.
Lucky they're common and inexpensive!
PostPosted: Mon Apr 01, 2013 7:21 pm
I'd be happy to - but aren't the turbo ones bigger for the both outrigger bearings?
Might have to measure up tomorrow.
Matt
PostPosted: Mon Apr 01, 2013 8:01 pm
Those outer casings need to be a tight interference fit, usually heat AND a puller is needed to get them out.
If it's not loose fit then loctite maybe, but seems pretty risky... any rotation at all is really bad there.
cheers,
Jacob
PostPosted: Mon Apr 01, 2013 9:50 pm
The hole looks oversized and worn to me, time for another case.
If it's a turbo box you could fit a standard (late rodchange box) housing, and put the standard bearing in it?
People on here have put 125HP+ @ the wheels through standard cases without outrigger bearing problems.
