Subframe reinforcing; re David Vizard https://www.ausmini.com/forums/viewtopic.php?f=2&t=80997 |
Author: | Kennomini [ Sun Apr 07, 2013 11:20 am ] |
Post subject: | Subframe reinforcing; re David Vizard |
Has anyone got some pictures of a reinforced front subframe as David Vizard says it should be done ![]() I'm looking at doing this myself, the tie rod area and seam welding is easy. What I'm not clear on is the reinforcing plates that go on the rear floor pan mount sections and if their needs to be anymore in other areas. |
Author: | Wombat [ Mon Apr 08, 2013 6:15 am ] |
There was some discussion on this sometime ago -Madmatt is the bloke to talk to |
Author: | TheMiniMan [ Mon Apr 08, 2013 7:58 am ] |
when you`re down here next Kenno i can show you all the ins & outs of frames strengthen-ings easy-peasy |
Author: | miniDave [ Mon Apr 08, 2013 5:25 pm ] |
TheMiniMan wrote: when you`re down here next Kenno i can show you all the ins & outs of frames strengthen-ings easy-peasy
Just about to weld up my subframes for the Monte replica gravel rally car - so any tips or sketches I can start with Matt???? EDIT: found this on a UK forum - http://forum.minicooper.org/showthread.php?t=11955 |
