It is currently Sun Jul 27, 2025 11:05 pm
PostPosted: Thu Sep 23, 2010 7:55 pm
Anyone fitted one of these before?
http://www.minispares.com/Product.aspx?ty=pb&pid=35729
It is a housing to fit a mechanical type oil temp sender unit. You can fit it into your oil cooler lines.
I have an oil temp guage with sender etc, but have not been able to decide on how to fit the sender unit. i was thinking along the lines of the sump plug fitting, but thats not ideal as you would disturb it every time you do an oil change.
question i had for anyone who has one, does it leak? there is a fair bit of oil pressure in the cooler line, what are the chances of it leaking or a hose popping off?
PostPosted: Thu Sep 23, 2010 9:25 pm
I've been looking at the same part, and had exactly the same questions... :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Apr 07, 2013 7:48 am
Here's one solution:
http://www.turbominis.co.uk/forums/inde ... t&tid=4569
'68 Deluxe w/Metro engine
