It is currently Sun Aug 03, 2025 9:46 pm
PostPosted: Tue Apr 09, 2013 2:21 pm
Hi All,
Does the A Pillar normally have a piece of cardboard with headlier fabric covering it?
Most of the headliners i've seen around to buy only come with the headliner, C Pillar covers and a bit for blow the rear window.
also... does anyone have a template and / or dimensions for the cardboard that is used to stiffen the material for the C Pillar covering?
Thanks!
1975 Hairy Lime/White Clubby
PostPosted: Tue Apr 09, 2013 2:33 pm
Minis from factory has no material on the A and B pillars, but if you have the offcuts it does look quite good to do it.
PostPosted: Tue Apr 09, 2013 9:16 pm
English Coopers came from the factory with the same vinyl covering on the A pillars as the dash top....
Cheers, Ian
PostPosted: Tue Apr 09, 2013 9:32 pm
Any chance you'd have a picture of the a pillar on one of these?
I'm thinking of covering the A-Pillar on my clubby in the same way as the C Pillar but im not sure exactly how to do it / what it will end up looking like.
PostPosted: Tue Apr 09, 2013 9:53 pm
LS's had material on the 'B' pillar too!
 Post subject: A Pillars covering
PostPosted: Tue Apr 09, 2013 10:25 pm
A pillars look neater covered in Vinyl. I also glue a strip of thin 1/4" medium density Foam on the pillar first then I use a nice Black Vinyl. Only glue the vinyl to the pillar not the foam. It sits neater. leave the edge long enough to wrap around under the windscreen and door rubber.
"Let us remove your "SHORTS"
 Post subject: Re: A Pillars covering
PostPosted: Tue Apr 09, 2013 11:23 pm
Thanks for this idea, I was going to use card like the C Pillar but this sounds like a better idea.
about how wide do you make the foam strip?
Users browsing this forum: drmini in aust and 95 guests
