It is currently Sun Aug 10, 2025 3:21 pm
PostPosted: Sat Apr 13, 2013 11:24 am
Die Die Die!!
i've recently had my subframes powdercoated, and now the threads are coated.. is there a way around this as its very difficult to screw in the bolts..
Nick
PostPosted: Sat Apr 13, 2013 11:37 am
Next time, put a bolt in there!
Your next move should be to try and tap it out.
Ideally, you want two taps. An old one to run through first with plenty of cutting paste, and a new clean one later.
The first one might do enough of a job, I've had to use two before on some stuff that was 2 packed because the primer was acting as an abrasive on the tap - thats why you sacrifice the first one.
PostPosted: Sat Apr 13, 2013 12:09 pm
Die Die Die!!
hmm ok, i had a feeling i should have left one in there when powder coating D'oh!
off to bunnings it is then..
PostPosted: Sat Apr 13, 2013 2:11 pm
Old bolts are the go. We also use ear plugs in place of bolts if its just going to the paint shop works a treat
66 Van 1275
69 K Sedan
69 K Van Teabag
66 austin Countryman
68van
PostPosted: Sat Apr 13, 2013 3:43 pm
You will be lucky to find suitable taps at Bunnings..
All they seem to have is metric these days.
If you want UNF or UNC taps, go to a fastener or engineering supplies shop.
