It is currently Thu Aug 14, 2025 3:04 pm
PostPosted: Sun Apr 14, 2013 9:14 pm
I have a 63 850 that was rebuilt with a Leyland mini so it now has the three dial cluster and top dash rail. So ignoring the holes in the top and lower steel dash rails how do you deal with the wiring issue :?:
PostPosted: Sun Apr 14, 2013 9:17 pm
You might be able to source a converter plug that goes from rover / leyland dash plug to older individual wires and plugs. The japs used them in their rovers when they retro-fitted the older style dash.
I used to have one - long gone now though.
PostPosted: Sun Apr 14, 2013 9:56 pm
Maybe easier to try and get a front wiring harness for a round nose mini as there are a number of differences between the two
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Apr 15, 2013 10:32 am
I did that the other week, there's surprisingly not too many differences in the wiring. It's really a matter of chopping the plug off for the guage cluster and re-terminating all of the wires. get a wiring diagram and you can see which wire is for which light / guage and away you go.
The one thing I haven't fixed yet is the fuel guage, I assume the senders are different, but haven't investigated that too much.
'78 LS 1275
PostPosted: Mon Apr 15, 2013 11:00 am
Senders roundy/Clubby are the same... (unless it's getting the old 850 fast-acting gauge in it)
PostPosted: Mon Apr 15, 2013 12:28 pm
mine is an early 850 fuel gauge which sounds like the problem..
I used this as a bit of a guide as well: http://www.theminiforum.co.uk/forums/in ... pic=115376
'78 LS 1275
PostPosted: Mon Apr 15, 2013 6:03 pm
Is their somewhere I can get a plug that matches the clubby loom so I don't have to chop the plug off? Then I can re-wire it to match the early dash.
PostPosted: Mon Apr 15, 2013 7:10 pm
There is/was an aftermarket loom for this in the UK, but I had no joy finding it last time I looked.
PostPosted: Mon Apr 15, 2013 9:02 pm
Was it this one Doc ?
http://www.minispares.com/product/Class ... 0to%20shop
PostPosted: Mon Apr 15, 2013 10:06 pm
Yes that's it. :wink:
Users browsing this forum: Bing [Bot], crisonic and 183 guests
