It is currently Sat Jul 19, 2025 6:56 am
 Post subject: Heat proof paint
PostPosted: Fri May 03, 2013 1:49 pm
Hi fellow ausminians i have a couple of questions on the temprature engine parts get upto for the following please , for painting.
Head ?
Block/gearbox ?
Exhaust manifold ?
Exhaust ?
Brake Drums ?
Cheers Bill
PostPosted: Fri May 03, 2013 2:18 pm
For a start the head, block and gear box shouldn't be any hotter than your thermostat - about 88*C - so less than boiling water. Any reasonable exterior paint should do -or use a paint for metal as it's designed to withstand a bit of expansion and contraction.
David L
PostPosted: Fri May 03, 2013 2:23 pm
Exhaust manifolds can reach 900C or more, use a Hi-temp paint rated for this application. or, use pot belly black. 8)
Use it on the zorst too.
You could get the manifold ceramic coated but it costs $$$.
PostPosted: Fri May 03, 2013 2:43 pm
Thanks for the answers guys i will be using high heat paint but noticed they have a few temprature ranges so wanted to get the right ones.
The exhaust i picked up already is painted black and i have no idea if it was heat paint or not so looks like i will be sanding it off and painting it as im guessing if the other paint is not heat paint it would peel off.
Cheers Bill
PostPosted: Sat May 04, 2013 3:06 pm
painted mine in 2pac so far 2 years on, no dramas
