Fitting twin 1,1/4 su's
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81137
Author:  Kermit [ Thu Apr 18, 2013 11:58 pm ]
Post subject:  Fitting twin 1,1/4 su's
Hi guys, car is all booked in to get the final things it needs for it's rwc done and im looking at doing a bit of a tune up first as well, extractors, exhaust and twin su's but im wondering if there is anything extra i need to get it going properly? the su's are complete and have everything there ready to bolt on.
Author:  MattE [ Fri Apr 19, 2013 6:18 am ]
Kermit,
Any more info?
Or perhaps a more precise question?
(Perhaps others know more about your car, but I for one am struggling to help with the info supplied).
Only things that come to mind is you might want the little rings to locate the new inlet manifold, and maybe some of the long type brass nuts.
Matt
Author:  Kermit [ Fri Apr 19, 2013 8:05 am ]
Sorry was half asleep when I wrote this. I'm wondering if I need to upgrade the fuel pump or anything like that? Or will I be able to use everything I have (stock 998) and fit it and go?
Author:  NG [ Fri Apr 19, 2013 8:29 am ]
you can use the mechanical fuel pump for sure.
i prefer a electric one but that works & worked for many years.
Author:  simon k [ Fri Apr 19, 2013 10:09 am ]
what needles are in the SU's? how worn or not are they? can you tune it yourself without driving it on the road after you change all that?
if it's running and *should* pass a roadworthy, then do that before you start changing things - when you take it to a guru to tune it for you, they'll want to drive it
Author:  Kermit [ Fri Apr 19, 2013 10:04 pm ]
Ok cool so my pump will be fine thanks for that :), can always upgrade to an electric one later on.
It's fully reconditioned so they're new? I'm going to get the mechanic to fit and tune these with the exhaust at the same time :)
