I got my new engine! https://www.ausmini.com/forums/viewtopic.php?f=2&t=8117 |
Author: | dansedgli [ Wed Jun 15, 2005 2:32 pm ] |
Post subject: | I got my new engine! |
Well, I just got back from NSW last night. I had to go to drop off a falcon bottom end but on the way back I dropped by twincammini's place to pick up the new powerplant that is going in the mini!! Its a CB70 turbo DOHC EFI daihatsu engine. 105hp standard. Ive got it sitting next to the original A series and its pretty similar in sizing. Its a little bit shorter, The head is a bit deeper but no wider than the block of an A series. It should fit in pretty well I think. Ive already started plugging the factory ECU in to make sure Ive got all the wiring I need, its pretty easy as the loom has all the plugs on it. Its like a big puzzle where you just need to find where everything fits. Once I get my other car back from the mechanic ( who managed to clear my haltech so its undriveable ATM ![]() Hopefully getting the engine in and running doesnt take more than a few months. Then I can start on the rest of the restoration. -Also thanks for the ride in your mini Chris, that thing felt so fast. I loved it! Its an awesome car! I cant wait till mine goes that well! |
Author: | J_A_M [ Wed Jun 15, 2005 3:08 pm ] |
![]() For my next trick...I am seriously thinking about a Hybrid roundy as another long term project. |
Author: | Mini Mad [ Wed Jun 15, 2005 3:16 pm ] |
Many years ago I saw a mini with a CB70 in it...went like dogs balls and handled on rails. Was owned by a guy that my sisters bf at the time knew. Sadly I only saw the car once and don't know what has happened to it since... I remember it being all over the ass of a WRX, neither could shake each other ![]() |
Author: | awdmoke [ Wed Jun 15, 2005 3:26 pm ] |
Good Luck ![]() and keep us posted. Will you actually save some weight with that Honda motor/g'box ? Mike |
Author: | dansedgli [ Wed Jun 15, 2005 4:38 pm ] |
awdmoke wrote: Good Luck
![]() and keep us posted. Will you actually save some weight with that Honda motor/g'box ? Mike Honda?? It feels a bit lighter to lift and move around without the gearbox but I havent properly weighed them both yet. I cant wait to get it all in and running. Hopefully it doesnt become a long term project. |
Author: | awdmoke [ Wed Jun 15, 2005 5:47 pm ] |
Honda?? Ooops - It's just that every time I hear CB I think Honda motorbikes ![]() |
Author: | awdmoke [ Wed Jun 15, 2005 6:04 pm ] |
BTW you can use those cheap bathroom scales to weigh the motor & even the axle weights. It's quite accurate. If the rotary dial spins right around & past zero, just add the two numbers: e.g. 140kg (typical max.) + 45kg = 185kg A couple of tips: - put a bit of ply or similar on top of the scales to spread the load - put bricks or wood to "ramp" a tyre onto the scale if taking axle mass I only put bricks on one side of the scale when weighing my trailer, and broke the scale when I rolled it off the other side. Oh well, it was scungy anyway. Bought a new one for $10 at Kmart. Mike |
Author: | minster [ Wed Jun 15, 2005 6:15 pm ] |
Post subject: | . |
Sounds like an interesting conversion. Good luck with it. Have you got any photos of the comparison between the mini engine and gearbox and the daihatsu engine and gearbox? |
Author: | dansedgli [ Wed Jun 15, 2005 6:22 pm ] |
nope not yet, I went out with a camera just before to take pics but I couldnt be bothered moving them next to each other. |
Author: | poeee [ Wed Jun 15, 2005 6:28 pm ] |
A while back I went to have a look at an unfinished project roundnose that had a CB60 (SOHC version, same thing). The guy said that link automotive had built the subframe for him, and cost him less than $2k I think he said. Maybe you should go have a talk to them? |
