CV Joints https://www.ausmini.com/forums/viewtopic.php?f=2&t=81201 |
Author: | Huelin2008 [ Tue Apr 23, 2013 11:56 am ] |
Post subject: | CV Joints |
is there anyway of telling of a CV joint is buggered when it is out of the car.... when the car was driving it felt fine, but i have noticed that one has been replaced already..... or am i just better or replacing both The bearing cage was difficult to turn on the angle to release the bearings on the older on!! HELP!! |
Author: | Boostedmini [ Tue Apr 23, 2013 3:32 pm ] |
In my mind, at 25 pound each plus freight, replace them. Grant |
Author: | Mick [ Tue Apr 23, 2013 9:22 pm ] |
If they clatter at full lock, then they're gone. No clatter, no problem. Good opportunity to change the boots and the grease however. They are pretty cheap however as boosted has said. |
Author: | John Smidt [ Tue Apr 23, 2013 9:30 pm ] |
Pull them apart check for wear in main body, if nill then put them back together with some new grease, And fit them to the oposite side you removed them from If they are a little old and canadian made or Australian made they will be a lot better than any thing You Will buy today |
Author: | drmini in aust [ Wed Apr 24, 2013 7:10 pm ] |
If CVs clatter on full lock it's usually because the grease has dried out or gone awol. Mine don't clatter, even though they have a bit of rotational movement. I have done ~130,000 miles on them now and they were on the car when bought. They have just been repacked and rebooted a couple of times. ![]() |
Author: | Huelin2008 [ Wed Apr 24, 2013 7:28 pm ] |
Thanks for the advise... But I have spoken to the "minister of finance" and we/me are just going to replace them while out....! As said, they seem cheap enough and looks like a nightmare of a job if the car was back together! Thanks |
