What year is this mini?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81227
Page 1 of 3
Author:  keithb [ Thu Apr 25, 2013 2:55 pm ]
Post subject:  What year is this mini?
Hi all
Have searched but cannot locate any info on chassis numbers years.
I have picked up a shell and the number is 24156, does anyone know what year this is?
Author:  Mick [ Thu Apr 25, 2013 5:04 pm ]
Give a little more information on the shell and life will get a little easier. Vin/ID plate details for example.
A few photographs of things like the engine bay, cabin and rear parcel tray will also help.
Mick
Author:  keithb [ Thu Apr 25, 2013 5:40 pm ]
It doesnt have a vin plate. all it has is the number stamped in the radiator cowling.
surely by the sequence of the factory numbers it can be worked out what year it was made?
I dont need the exact date just the year is enough.
thanks
Author:  Kennomini [ Thu Apr 25, 2013 6:02 pm ]
Is it a square or round nose?
Their is also a body number stamped on the fire wall behind the master cylinders, I think that is more important than the radiator shroud number.
Author:  Convertible Mini [ Thu Apr 25, 2013 6:14 pm ]
Post subject:  No Vin Plate....
No Vin Plate?.. Call it Mk 2 Cooper S.
Author:  keithb [ Thu Apr 25, 2013 6:53 pm ]
It's a round nose. There are no numbers by the master cylinder. Vin plate has been removed. It's not a cooper.
Author:  niceboy1275 [ Thu Apr 25, 2013 6:59 pm ]
Does it have any doors? or windows, boot lid lock, wiper motor? These items can help it be dated..
Where is the hole for the gear stick? between the seats or at the bottom of the fire wall? Does it have subframes? All these things can help date the car if you have any info.
Author:  danny_ [ Thu Apr 25, 2013 7:03 pm ]
Post subject:  Re: No Vin Plate....
Author:  keithb [ Thu Apr 25, 2013 7:09 pm ]
It is a remote gear change. Wind up windows. No wiper motor. No sub frames. I can't believe no one can hazard an educated guess to its year based on the chassis number? Surely one of the anoraks on here knows.
Author:  womble99 [ Thu Apr 25, 2013 7:12 pm ]
Post subject:  Re: What year is this mini?
keithb wrote:
Hi all
I would hazard a guess it is a 67, since mine is 30062 and is meant to be end 67 or early 68
cheers,
CJ
Author:  keithb [ Thu Apr 25, 2013 7:17 pm ]
It's feasible that its an early 67 or late 66?
Author:  John Smidt [ Thu Apr 25, 2013 7:17 pm ]
There are a couple of ways You may be able to narrow it down
First Thing Check if any electric parts still fitted, such as Horn, Fuse Box, Voltage Regulator Wiper motor etc
Then check if the boot lock is still fitted,
if none of the above Then check the distance between the holes in body for wiper posts, Check The floor pressing, if Raised section for brake or hydro lines
Check if large or small hole in Bulk head between subframe bolts or studs
Check B panel see if latch has three hole in vertical line or two holes in line and one offse.t check is fire wall has a captive nut either side of large hole
Author:  John Sneddon [ Thu Apr 25, 2013 8:41 pm ]
Post subject:  Chassis Number
Educated guess based on data I have Mid 67
Author:  dodge [ Thu Apr 25, 2013 9:52 pm ]
which way do the wipers park, has it got glass ? there is alwas a date code on the glass
Author:  thomas_hb [ Thu Apr 25, 2013 10:04 pm ]
I can't believe with this attitude you've got even this far.
Page 1 of 3 All times are UTC + 10 hours
