Copper brake pipes
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81228
Author:  spfh84 [ Thu Apr 25, 2013 3:04 pm ]
Post subject:  Copper brake pipes
Does anyone know if these are copper brake lines or kunifer? If they're copper I suppose they're illegal right? Thanks
http://www.minispares.com/product/Class ... |Back%20to
Author:  drmini in aust [ Thu Apr 25, 2013 3:51 pm ]
They are copper, it says so in the sales blurb.
I would be tempted to use it for the hydro lines (Minispares sells a 4 piece kit with 2 joiner sockets), but not brake lines...
Author:  Mick [ Thu Apr 25, 2013 4:30 pm ]
Is it possible some of these copper brake line kits are copper plated steel to stave off corrosion?
Author:  drmini in aust [ Thu Apr 25, 2013 7:08 pm ]
Copper tube is commonly used for brake piping in UK.
If you want the best brake pipe use cupro-nickel, available here. It won't rust and is way stronger than copper.
The problem with copper tube is it work hardens with age or movement, gets brittle then can break.
Author:  spfh84 [ Thu Apr 25, 2013 7:57 pm ]
is it illegal? Seems strange that the UK would allow it!
Author:  Timbo [ Thu Apr 25, 2013 8:39 pm ]
The UK covers its roads with salt, they would all die if they used steel brake lines. They commonly use copper, cupro nickel or cunifer brake lines, mainly for the corrosion resistance.
Author:  jubblies [ Wed May 08, 2013 10:32 pm ]
OK, so I'm looking at getting some new brake lines and saw that some UK companies do copper and some do Cunifer (cupro-nickel)
This brings me to a few questions;
1: Is it Legal? (ADRs)
2: Does it work Harden?
Author:  kirby [ Thu May 09, 2013 1:49 am ]
It is legal providing it meets adrs or equivalent ISO, SAE etc.
It does work harden but not in anyway like copper.
Its also very easy to work with. It doesn't need a heavy duty flare-ing tool like steel does.
Author:  Babes [ Thu May 09, 2013 8:35 am ]
Just go to your local enzed or similar hose shop and grab a roll of brake line. Make them yourself it is extremely easy to do. If you dont have a double flare tool or pipe cutter just take the old ones and get them to bend them up and put the ends on.
Author:  simon k [ Sat May 11, 2013 3:07 pm ]
that makes sense - I did wonder
my mate inspected a dodgy compliance/roadworthy on a UK import Maserati, looking underneath it when it was brought in and all of the brake lines were completely rusted (among lots of other nasties)
Author:  9YaTaH [ Sat May 11, 2013 3:25 pm ]
Dumb question: but Doc, would copper stand the same pressures as steel? Remembering around 300-320psi (on first pump up) :?:
Author:  drmini in aust [ Sat May 11, 2013 3:30 pm ]
Yes no problem.
You can also get a pipe kit in UK with plastic line instead.
Back in 1970 I used to plumb the brake lines on Formula Vees using 1/8" nylon line, and crimped brass end fittings. No rubber hoses. The nylon was rated for 2,500psi.
