roundnose front indicator lense https://www.ausmini.com/forums/viewtopic.php?f=2&t=81240 |
Author: | Ryan1980 [ Fri Apr 26, 2013 3:44 pm ] |
Post subject: | roundnose front indicator lense |
how on earth do they go on ? I bought new rubber seals, are they only held on by the seal? I can not for the life of me get the lense into the seal. on another note, is it just me or is the search function not working very well? for example, a search on 'indicator' on all forums only yielded around 10 results. |
Author: | drmini in aust [ Fri Apr 26, 2013 3:53 pm ] |
You work them into the seal, then fit the chromed steel ring into the outer groove. A bit of soap helps. [edit] search function has been disabled to keep ausmini alive (for now). Use google to search. |
Author: | Harley [ Fri Apr 26, 2013 3:55 pm ] |
Search function is broken - it can only look at results after feb/mar when the last crash occured. To get the seals in, the chrome ring needs to come out, screw the base in, fit the globe and glass lense, then the chrome ring holds it all in. |
Author: | Ryan1980 [ Fri Apr 26, 2013 4:40 pm ] |
thanks guys. thats a real pity about the search - so many years of information - i hope it can be restored! ![]() |
Author: | Harley [ Fri Apr 26, 2013 4:52 pm ] |
The info is still there, you just can't search for it. Go to google, type in what you want, then add "site:ausmini.com/forums" to it. |
