Fitting CV Boots UPDATE
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81251
Author:  phillb [ Sat Apr 27, 2013 9:56 am ]
Post subject:  Fitting CV Boots UPDATE
I fitted a new CV boot the other day and it has popped off.
I was wondering if I tried to do the retainer up too tight or if some of the boots are just not the right shape at the lip.
Is there a trick to getting these things to stay on?
Author:  MiniBill [ Sat Apr 27, 2013 11:17 am ]
Havent done mine yet , but i have noticed 2 different kits so far , 1 with the stainless steel clip and 1 with the cable tie's , try the cable tie route if you havent............ unless the brainstrust here has a special way.
Cheers Bill
Author:  dalmeny [ Sat Apr 27, 2013 12:04 pm ]
Phil, I always wipe the grease off the inner edge of the boot and CV, so that when you slip it on it's not slipping around in grease.
Author:  drmini in aust [ Sat Apr 27, 2013 1:35 pm ]
The metal clamps are way better than cable ties. But they need to be tight. If you don't have the special tool (that Lillee has) use 2 pr of pliers.
Author:  phillb [ Sat Apr 27, 2013 2:56 pm ]
OK I've refitted using a metal strip, I think I may have not had it in quite the right spot first time round.
The old boot I removed seemed to have a much more definite 'v' to engage the groove in the CV.
I'll keep an eye on it.
Thanks guys.
Author:  phillb [ Mon Apr 29, 2013 9:18 pm ]
I realise now having just done the other side that the CV's fitted to the first side (which I had trouble with) had a different design.
The "groove" for the cover seal was more a "V", was closer to the edge of the CV and the original boot seemed to be designed for it.
The one I just did the groove is rounded and much deeper into the hub and the new boot was a perfect fit.
