Shallow Weber Box Dimensions? https://www.ausmini.com/forums/viewtopic.php?f=2&t=81275 |
Author: | Cooper_Matrikon [ Mon Apr 29, 2013 9:21 am ] |
Post subject: | Shallow Weber Box Dimensions? |
Has anyone fabricated a shallow Weber box allowing the installation of said carby whilst retaining the centre speedo/binnacle? Also, how much room are we talking between the back of the bulkhead and the speedo? I know there are off the shelf items and battery boxes are a possibility, but I was hoping to fabricate something that is a happy medium to allow better air flow, whilst not disrupting the doings of the speedo et al. Here's a prefab one from Retro Minis in Lancashire. ![]() "the actual box measures as follows, meaning the hole size needs to be bit bigger, the front flaps are just over 1/2 in 15mm wide Length 11in 280mm Height 7in 177mm Depth in bottom 7in 177mm Depth in top 2 1/2in 62mm Slope on front 8 1/4in 209mm" |
Author: | drmini in aust [ Mon Apr 29, 2013 9:42 am ] |
Lillee has a fairly shallow one, was fitted by Mini Classic in Ermington. However he still had to move the speedo pod outwards an inch or two and use a 90° drive box on the speedo head. Also, he found it would not take a decent sized K&N filter so he is running 2x Unifilter socks. His manifold is an RE5. It all depends what filter you want to use, and how long the manifold is. If you run a Redline 3005 you can fit a Ramflo R445-P5 with NO Weber box. Properly ported, these manifolds are OK for up to 125HP at the crank (like my 1360). |
Author: | Cooper_Matrikon [ Mon Apr 29, 2013 10:57 am ] |
Thanks again Doc. I cant seem to find that part number online. Karcraft? |
Author: | Cooper_Matrikon [ Mon Apr 29, 2013 11:33 am ] |
Thanks Doc and Lillee for entertaining my inane questioning on this! Lillee, the shots give me a good idea now. As for a peek at Rylstone, I'm hoping to be up and running in the next few weeks! |
Author: | Cooper_Matrikon [ Mon Apr 29, 2013 11:40 am ] |
Looking at an earlier post of yours Doc, you mentioned some people pop rivet them in, but your weren't sure as to legality of this approach. Any more word on that? |
Author: | drmini in aust [ Mon Apr 29, 2013 11:54 am ] |
Cooper_Matrikon wrote: Thanks again Doc. I cant seem to find that part number online. Karcraft?
p/no of manifold is 12-3005. I just yesterday sold a s/h one of Baracade's, to Sam_1100. http://www.redlineauto.com.au/products/ ... y/CFBHTSMX The RF445P5 is a Lynx number, P5 means offset upwards. re fitting the box, ask Lillee what grief he then had moving the wiring... ![]() |
Author: | Cooper_Matrikon [ Mon Apr 29, 2013 2:21 pm ] |
Quote: The RF445P5 is a Lynx number, P5 means offset upwards. The air filter is the one I cant find. ![]() |
Author: | drmini in aust [ Mon Apr 29, 2013 4:02 pm ] |
Cooper_Matrikon wrote: Quote: The RF445P5 is a Lynx number, P5 means offset upwards. The air filter is the one I cant find. ![]() It's because the P5 offset backplate is NLA, Chong and I had trouble last time and had to order 6 of em... You could buy an RF445S and I can weld the holes and remachine them, but it's a PITA to do. PM sent. |
Author: | SuperCooper [ Mon Apr 29, 2013 7:58 pm ] |
What manifold will you be running Evan? Do you really need to add a weber box? |
