It is currently Wed Jul 30, 2025 6:55 pm
Does any one elce have heaps of problems with their mini?
Poll ended at Tue Mar 11, 2008 6:16 pm
Yes 67%  67%  [ 8 ]
No 33%  33%  [ 4 ]
Total votes : 12
PostPosted: Thu Jun 16, 2005 6:14 pm
I tried to put my new rims on today got the rubber put on and the rear wheel well the tires will not fit by like 2mm i can get tires that are 10mm smaller but geez i thought every thing will be fine now but does any thing go smoothly with my mini.....NO
PostPosted: Thu Jun 16, 2005 6:42 pm
so,metimes/ but then soon all the probs will be fixed and it will go great for ages
they are up to 45 yo now days :shock:
PostPosted: Thu Jun 16, 2005 6:51 pm
Mine is great, sure it has it's problems, but i've only ever had one real major problem that I couldn't fix myself on the side of the road or got home to fix..
Daily driver for 3 years, 500km's a week.. Engine is given a bit of a hard time as well :wink:..that's why it died once..or twice :lol:
You have to do preventative maintenance though..check things and replace them..or if you know that something is going to break and you leave it long enough..be prepared for it to break..like my throttle cable once did...
If you plan on keeping the car, I like getting stuff replaced so you know the condition of it later down the track like "oh yea i replaced all that back in..."
Chris that's why you get a clubby, they're the younger prettier late 20 year old's with less mileage ;)
PostPosted: Thu Jun 16, 2005 6:55 pm
mine has a new problem everyday and they just keep getting worse and worse :(
PostPosted: Thu Jun 16, 2005 8:22 pm
It's a Mini we all get unexpected faults with them.
On my way home form the Muster Mine stopped all of a sudden and then I heard the fuel pump pumping madly and I thught it was stuffed.
But no the fuel tank had gotten a vacum seal and the Breather for the tank was blocked so I changed filler cpas from one side to the other and all was ok.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Thu Jun 16, 2005 8:46 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
have you got spaced drums on it ??
makka
