It is currently Sat Jul 19, 2025 10:39 am
PostPosted: Sat May 04, 2013 8:38 pm
Just wondering on options on replacing 5/16 wheel cylinders with 1 inch wheel cylinders on a drum brake mini......
I have heard the 1 inch give better braking
PostPosted: Sat May 04, 2013 9:35 pm
no such thing as a 5/16 wheel cylinder,sorry :?
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Sat May 04, 2013 9:37 pm
Probably means 15/16
PostPosted: Sat May 04, 2013 9:40 pm
There there were both 15/16" and 1" cylinders used on twin leading shoe front brakes.
1" ones will give lighter pedal pressure at the expense of a bit more pedal travel, for the same braking effort. Or more braking for the same pedal pressure as you say.
Just don't mix them up... they all need to be the same. :lol:
PostPosted: Sat May 04, 2013 9:49 pm
Thanks dr
Exactly the answer I was after
