5/16 vs 1 Inch wheel cylinders!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81341
Author:  Huelin2008 [ Sat May 04, 2013 8:38 pm ]
Post subject:  5/16 vs 1 Inch wheel cylinders!
Just wondering on options on replacing 5/16 wheel cylinders with 1 inch wheel cylinders on a drum brake mini......
I have heard the 1 inch give better braking
Author:  DA9jeff [ Sat May 04, 2013 9:35 pm ]
no such thing as a 5/16 wheel cylinder,sorry :?
Author:  guna mk1 [ Sat May 04, 2013 9:37 pm ]
Probably means 15/16
Author:  drmini in aust [ Sat May 04, 2013 9:40 pm ]
There there were both 15/16" and 1" cylinders used on twin leading shoe front brakes.
1" ones will give lighter pedal pressure at the expense of a bit more pedal travel, for the same braking effort. Or more braking for the same pedal pressure as you say.
Just don't mix them up... they all need to be the same. :lol:
Author:  Huelin2008 [ Sat May 04, 2013 9:49 pm ]
Thanks dr
Exactly the answer I was after
