It is currently Tue Jul 29, 2025 5:34 pm
 Post subject: Oil pumps
PostPosted: Wed Jun 15, 2005 9:48 pm
I have made 1 motor from 2.
As a result, I have 2 of a lot of things, including oil pumps.
Tonight I fitted one, but observed the following:
One was worn pretty bad. Good thing I checked, as this was the one I was going to use :shock:
The oil pump from the 1098 seems like an after market. There are no identity markings on it at all!
The one I eventually used was this one. It says 'Patent Pending' on it :lol: It was the one from my original 998. A genuine part I believe.
Anyone know how many different pumps are available, and their origins?
PostPosted: Wed Jun 15, 2005 9:50 pm
Not many different ones now for a 998/1098.
Get a new one, don't trust a worn S/H one. $47 at Karcraft. Cheap! :lol:
PostPosted: Wed Jun 15, 2005 9:52 pm
throw them both away - buy a new one, should be on everyone's list, when you have the front off a motor, put in a new pump...
PostPosted: Wed Jun 15, 2005 9:55 pm
Once upon a time, the Cooper S pump was bigger capacity than the 998/1098 one- we used to press the (shorter) 998 shaft into an S pump and fit that in. Eventually BMC made the pump rotors the same size.. :lol:
PostPosted: Wed Jun 15, 2005 10:04 pm
you can still buy a 'high capacity' pump can't you?
or is that just marketing the same thing for a higher price
PostPosted: Wed Jun 15, 2005 10:11 pm
There is the MiniSpares Sureflo which Karcraft bring in for S's, these are available in UK for other motors too.
There are a few others too- turbo pump, steel backed pump, etc. But not for a 998 pin drive.
PostPosted: Thu Jun 16, 2005 11:08 am
Yeah anton, don't do it! Buy new...
The 1100S engine that we pulled apart has a near new oil pump as well but I am still going to consider buying new. It's false economy... $47 is darn good insurance if you ask me!
