Oil filler cap contacts bonnet. https://www.ausmini.com/forums/viewtopic.php?f=2&t=81449 |
Author: | phillb [ Thu May 16, 2013 7:00 am ] |
Post subject: | Oil filler cap contacts bonnet. |
Standard cooper s motor. Standard factory rocker cover. Standard factory style vented (taller) oil filler cap. Oil filler cap contacts bonnet crossmember when bonnet closed. If anything my bonnet is a little high along the rear edge rather than flush with the scuttle panel. Is this a common issue?? Suggestions/solutions appreciated. Cheers. |
Author: | ryan [ Thu May 16, 2013 7:17 am ] |
If this a new issue or something that's existed for a while? What type of engine mounts have you got? |
Author: | phillb [ Thu May 16, 2013 12:59 pm ] |
ryan wrote: If this a new issue or something that's existed for a while?
What type of engine mounts have you got? When I fitted the taller (correct) vented cap it became an issue although i took a while befor i realised it was rubbing. The non vented just fits I think. When I first got the car it had a fancy rover style alloy r cover and large Cental flip cap and it also contacted. Re the engine mounts I don't know what I have. Are some thicker? |
