captainwaldopepper wrote:
Thanks Dr Mini
I'll have to get myself a good magnetic dial gauge.
Pleas excuse my ignornace but once I find TDC using a dial gauge, how would I determine retarded/advanced settings in degrees.?
regards
Dave
You can put more advance marks round the pulley, it is basic trigonometry. Use a 6" steel rule to measure round.
Or you can bend a bit of sheet metal, bolt it next to the timing cover and mark that.
But it's easier to just put a TDC mark, and go buy a dialback timing light from `convertible mini' on here, he imports them. Or, go eBay and try your luck. Prices around $100 up.
These lights work great, you set the advance you want on the screen, it electronically moves the neon flash timing point. It has a tacho in it for rpm, you turn the dizzy until the marks align at whatever rpm you want.
I do mine at 4000 rpm which is past my max centrifugal advance point.
This is better for power than setting at idle and praying the dizzy advance curve is still correct after 40 years or so.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
