It is currently Wed Aug 06, 2025 2:29 am
PostPosted: Sun May 26, 2013 4:29 pm
I m at epping rd sydney ...cross road essex road...help 0422431412. In the middle of the freaken epping road[/list]
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
PostPosted: Sun May 26, 2013 5:18 pm
I hope you have been able to get off Epping road.
I am on the other side of the city so i am no help..
Have you been able to sort it out?
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Sun May 26, 2013 7:36 pm
High heel ninja
Push it, its only a mini!
PostPosted: Mon May 27, 2013 9:23 am
LOL
didnt realise this was the NRMA....
:lol:
PostPosted: Wed May 29, 2013 8:07 pm
Yea...my phone was on 1% battery. Better SOS here.....as wait on the phone keep drainingbattery.
I couldnt hv finished typing asking people to call for me and its dead. Lucky saw cop n helped me push to the side
Anyway, what maybe the issue. In any gear on stationary engine doesnt stall.....weird.... :shock: .....then push gas pedal...km/h goes up like u are driving it but no movement in any gear.
Differential? Clutch ? But the clutch has good friction and the NRMA inspected it and cannot figure it out. He saw the lever moves when i apply the clutch pedal on and off...
He says maybe the draft shaft it happens to powerful car he says.
Is it big crap on this one?
Still no time to deal with it atm with work n family.....
PostPosted: Wed May 29, 2013 8:48 pm
May just needs adjusting....
Does it sound funny when engaging your clutch?
PostPosted: Wed May 29, 2013 9:39 pm
May have popped a driveshaft out of a CV, or broken one where it goes in. I've seen it happen (998 Clubby van).
PostPosted: Thu May 30, 2013 10:54 am
Yeah called Ben, I think it's a driveshaft issue rather than a clutch issue
PostPosted: Fri May 31, 2013 9:42 pm
By the way, I did some research and I prolly know where the problem is.
Will look for the CV joint and the CV axle tomorrow under the car.
If any one of these breaks the car won't go for sure (that's what the guy in uTube says).
Also I think I checked last time, put in gear it is like neutral but speedo goes up. I heard a bit of noise prior to that when I did a sharp right turn (so will check for the left CV first tomorrow), but the Mini went for another 2-3 kms before it breaks on the slope up on Epping road when I shift down gear, and it's not an instant break though. My research is below, seems matches my symtoms!!!!!!!
http://answers.yahoo.com/question/index ... 920AA1CXeV
http://www.youtube.com/watch?v=fMMutpmWr94
(between 2mins:11secs - 2mins:40sec)
By the way, is drive shaft and CV axle the same thing?
And also, should I get a 3 ball or 6 ball in the CV?
PostPosted: Fri May 31, 2013 9:58 pm
Driveshaft = axle.
CV has 6 balls, so does the pot joint. It is Japanese and Euro cars that have 3 balls (in the inner CV), not Minis.
PostPosted: Fri May 31, 2013 10:12 pm
I have sent a PM to Ben and will have a look at the car in the morning
We will then give an update
I suspect it is the same issue Watto had in his van last year?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jun 01, 2013 5:39 pm
I visited Ben this morning and checked out the front end
No oil leaks :roll:
Drive shafts and both inner and outer CV joints seem ok although one is leaking grease due to failed boot tie.
I suspect a diff failure, but as it is a non mini engine/gearbox unit it's outside of my mini limited memory banks
Good luck Ben
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Jun 09, 2013 12:47 pm
Some updates as people PM me asking.
Took it there last sat to Grieg. He basically started working on it on Tuesday and I got it back on the road on Weds. He took only 5.5 hours to fix it.
Grieg said the shaft was not broken. The shaft is basically a Mini shaft modified (cut short and resplined) to suit. Grieg inspected and saw the splines of the right hand side inner CV side were distorted (curved and not straight) as it was not deep enough. He said the circlip were not holding it.
He fixed it by welding and some other things with the rings. Too mechanical for me, but he said it is way much much better now.
It is sweet now....lol
He also inspected the gearbox n check the transmission oil. It was very clean.
He also told me if I wanna sell it plz let him know first as a customer of his were there last week and saw it and loves it n asking if I wanna sell.
Ben
PostPosted: Sun Jun 09, 2013 1:00 pm
Good to hear it was a relatively simple fix. Greig working his mini magic as usual :wink:
1969 Cooper "S"
1967 Mini Deluxe
