It is currently Sat Jul 19, 2025 9:44 am
 Post subject: Clutch Pressure Plate
PostPosted: Sat May 04, 2013 6:12 pm
I am looking for a pressure plate to have lightened (to suite a diaphragm spring).
Are they all the same, or is there one that it more amenable to lightening than another?
At one stage someone told me the “Cooper S” one was better (or did this relate to the tax :roll: ).
The part number on mine is 22A598.
PostPosted: Sat May 04, 2013 6:20 pm
you need 22g270
PostPosted: Sat May 04, 2013 6:38 pm
TK wrote:
you need 22g270
22G270 is genuine the Cooper S one and is SG iron rather than grey iron (so Vizard says).
However it takes a bit of work to lighten them properly without weakening them. It's NOT a good idea to just face them thinner.
Have seen a shattered one, I would suggest it's a safer plan to buy an MED or Swiftune light steel one. :wink:
http://www.med-engineering.co.uk/catalo ... -backplate
http://www.swiftune.com/Product/1066/sw ... plate.aspx
PostPosted: Sat May 04, 2013 7:13 pm
Agreed, wise words.
PostPosted: Sat May 04, 2013 8:12 pm
So I should sell the 22g270 Cooper S one I found and buy a MED one.
May be cost neutral, depending on how much tax people are willing to pay. :D
PostPosted: Sun May 05, 2013 2:48 pm
Indigo,
I have faced many Mini clutch backplates including the famous 22G270 one.
They all turn like grey cast iron, including the S one. :lol: I dispute whether they are really SG iron.
Cooper S tax eh- once installed you can't read the part number...:mrgreen:
PostPosted: Sun May 05, 2013 6:05 pm
The Mini King
The 22G270 His a ring to it when hit with a metal object, All others do Not
PostPosted: Mon May 06, 2013 10:30 am
Just buy one of these ...
im running the same one in mine
http://www.ebay.co.uk/itm/Austin-Mini-U ... 35c710a932
cheap as chips ... really good to deal with too
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon May 06, 2013 7:14 pm
Kev it would be interesting to do a spark test on the 270 versus 22a one
They are deffinantly different muck
PostPosted: Mon May 06, 2013 9:19 pm
Beanie,
Are you using their flywheel as well?
Would need some straps and probably spacers and then a balance.
PostPosted: Tue May 07, 2013 10:33 am
IndigoBlueCooperS wrote:
Beanie,
Ya flywheel too ...
i ordered the straps , spacers and bolts from Swiftune...
then had it all ballanced when it landed here .. flywheel and backing plate were pretty good .. it was the diaphram that was out the most ...
Beanie
HOTBRICKS
'65 NCF MINI.....
PostPosted: Sat Jun 01, 2013 6:50 pm
pm sent
Users browsing this forum: No registered users and 72 guests
