It is currently Fri Aug 08, 2025 7:58 am
 Post subject: clutch arm and plunger
PostPosted: Mon Jun 10, 2013 6:20 pm
Hi there,
just wanting to pick your brains about clutch arms and the thrust plunger that goes with it.
I had my mini on the road about 2 years ago and replaced the arm and plunger, drove it around for 6 months and then pulled the engine out for a rebuild. I have gotten back into it recently and I've noticed that there is a lot of wear for only 6 months driving!
Is this normal? can you buy hardened ones? is there a way to check if one is harder than the other as i'd rather change the arm every so often than the plunger.
thanks,
Leighton
PostPosted: Mon Jun 10, 2013 7:05 pm
Original ones were both hardened. Whether the current quality ones sold still are I'm not sure, but they need to be for durability.
[edit] If you cannot file the ball or the outside of the plunger (near the hole) they are hardened..
If you want to know `how hard', you need to take the parts to someone who has a Rockwell or similar hardness tester. eg a toolroom or heat treatment shop.
PostPosted: Tue Jun 11, 2013 4:28 pm
Is it possible to harden new arms?
PostPosted: Tue Jun 11, 2013 4:50 pm
I would send it back to the supplier if soft, and get my money back. Not fit for purpose..
You should not have to re-engineer NEW parts.
If the good ones are now unobtainium new, either find a good s/h one, or get one made to sample (out of heat treatable steel) on a CNC mill. Make a bunch get them hardened, and people will buy them.
This local manufacture has happened here already with various parts, eg Hi-Los.
PostPosted: Tue Jun 11, 2013 8:51 pm
Like me, get this;
http://www.med-engineering.co.uk/catalo ... clutch-arm
