Body Primer https://www.ausmini.com/forums/viewtopic.php?f=2&t=81767 |
Author: | AJ [ Thu Jun 13, 2013 8:42 am ] |
Post subject: | Body Primer |
I know this has been discussed before ....., but what would be the best treatment for a bodyshell after having all the paint removed ,by blasting or paint stripper etc. to stop it rusting ,until body is repaired and painted |
Author: | tomtom [ Thu Jun 13, 2013 9:48 am ] |
I believe that'd be etch primer. If you're getting it blasted have a chat to the mob and they might be able to do it for you soon after blasting too. |
Author: | meeni [ Thu Jun 13, 2013 10:05 am ] |
Epoxy or similar, dp40 by ppg |
Author: | DRNCOOPERS [ Thu Jun 13, 2013 12:23 pm ] |
Post subject: | primer |
if you are only wanting to spray something over it to stop it rusting, I found the best cheapest thing is the $2 pressure packs that are very often on special at a certain super auto place. I don't waste money on the special primers until all the body work is repaired and you are ready to paint the entire body. the $2 paint is easy to re-apply after you have worked on a section at a time, then easy to wipe off with thinners on a rag. |
Author: | michaelb [ Thu Jun 13, 2013 3:48 pm ] |
The guy who sand blasted my mini painted it with an etch primer which was pretty robust. |
Author: | AJ [ Thu Jun 13, 2013 7:45 pm ] |
Thanks for the replies guys ..... ![]() |
Author: | AEG163job [ Thu Jun 13, 2013 9:28 pm ] |
Be careful with etch primer. One product I used recently carried a warning: "This product must be overcoated with Primer Surfacer or Primer Filler as soon as possible after it is dry or product failure may occur" (Septone - of SuperCheat fame) |
Author: | CPOCSM [ Thu Jun 13, 2013 10:14 pm ] |
And be careful of priming it as most primers will suck up moisture like a sponge. Being in toowoomba and seeing the state of the bogan limos driving around town with rust streaks weeping out from under primed spots on every panel is amazing! Hooroo |
Author: | adnams4ever [ Fri Jun 14, 2013 5:09 pm ] |
meeni wrote: Epoxy or similar, dp40 by ppg
DP 40 is a great choice. But also should consider PPG 2K Epoxy Urethane...fantastic for restos. |
Author: | AJ [ Fri Jun 14, 2013 7:30 pm ] |
Does DP40 absorb moisture ?? what type of paint can use over it |
Author: | Gordo [ Fri Jun 14, 2013 8:53 pm ] |
Depends how long your going to leave it and where... Nearly any sort of primer will rust, if in doors and not for a great deal of time it'll do but if its outside it basically needs a undercoat or first coat... Believe me or not, I have been though it and its cheaper to get it done than too store it and have too do it all again |
