It is currently Fri Aug 01, 2025 10:08 pm
 Post subject: Body Primer
PostPosted: Thu Jun 13, 2013 8:42 am
I know this has been discussed before ....., but what would be the best treatment for a bodyshell after having all the paint removed ,by blasting or paint stripper etc. to stop it rusting ,until body is repaired and painted
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Thu Jun 13, 2013 9:48 am
I believe that'd be etch primer.
If you're getting it blasted have a chat to the mob and they might be able to do it for you soon after blasting too.
1978 Leyland Clubman
PostPosted: Thu Jun 13, 2013 10:05 am
Epoxy or similar, dp40 by ppg
Potato
 Post subject: primer
PostPosted: Thu Jun 13, 2013 12:23 pm
if you are only wanting to spray something over it to stop it rusting, I found the best cheapest thing is the $2 pressure packs that are very often on special at a certain super auto place. I don't waste money on the special primers until all the body work is repaired and you are ready to paint the entire body. the $2 paint is easy to re-apply after you have worked on a section at a time, then easy to wipe off with thinners on a rag.
PostPosted: Thu Jun 13, 2013 3:48 pm
The guy who sand blasted my mini painted it with an etch primer which was pretty robust.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Jun 13, 2013 7:45 pm
Thanks for the replies guys ..... :D . Looks like etch primer then
1965 Morris 850
1977 Leyland LS
PostPosted: Thu Jun 13, 2013 9:28 pm
Be careful with etch primer. One product I used recently carried a warning:
"This product must be overcoated with Primer Surfacer or Primer Filler as soon as possible after it is dry or product failure may occur"
(Septone - of SuperCheat fame)
PostPosted: Thu Jun 13, 2013 10:14 pm
And be careful of priming it as most primers will suck up moisture like a sponge. Being in toowoomba and seeing the state of the bogan limos driving around town with rust streaks weeping out from under primed spots on every panel is amazing!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Jun 14, 2013 5:09 pm
DP 40 is a great choice. But also should consider PPG 2K Epoxy Urethane...fantastic for restos.
63 Morris Cooper.
UK Mini van.
PostPosted: Fri Jun 14, 2013 7:30 pm
Does DP40 absorb moisture ?? what type of paint can use over it
1965 Morris 850
1977 Leyland LS
PostPosted: Fri Jun 14, 2013 8:53 pm
Depends how long your going to leave it and where... Nearly any sort of primer will rust, if in doors and not for a great deal of time it'll do but if its outside it basically needs a undercoat or first coat...
Believe me or not, I have been though it and its cheaper to get it done than too store it and have too do it all again
Life's a garden.... Dig It!
