It is currently Fri Jul 25, 2025 6:14 pm
PostPosted: Mon Jun 17, 2013 7:44 pm
So dad's car wasn't idling so well, so dad and I decided to check the ignition points gap. After adjusting them, dad proceeded putting it all back together. i then looked for the rotor button on the floor where I left it but it wasn't there, so I assumed dad had put it on already. He hadn't!! He put it in a 'safe place' off the floor so we wouldn't step on it. So I turned the car over, it chugged a few times then nothing, the car wont turn over anymore. I am presuming something is fried.
Has this happened to anyone else?
Any ideas?
PostPosted: Mon Jun 17, 2013 8:08 pm
How about trying with the rotor button fitted? :?
PostPosted: Mon Jun 17, 2013 8:48 pm
Yeah, I eventually tried with the button on but no cigar.
PostPosted: Mon Jun 17, 2013 9:50 pm
Did you perhaps knock the starter wire off of the solenoid when you where working around that area?
PostPosted: Mon Jun 17, 2013 9:57 pm
Unfortunately not. I can hear the solonoid clicking but that's it
PostPosted: Mon Jun 17, 2013 10:01 pm
Rover Cooper
Flat battery ;-)
PostPosted: Mon Jun 17, 2013 10:08 pm
Well it could be the solenoid, or the starter motor really.
To prove the solenoid, use a multimeter to measure the voltage across the solenoid posts when it clicks on. If it is zero volts, then it is fine, if it is 12 volts, then it isn't working. A simpler proof of this is to tap a spanner across the terminals, you will get some sparks and the motor will turn over.
if the solenoid is fine, and the starter motor isn't stuffed, then It might be the brushes on the starter motor not seating on the commutator properly. Put a spanner onto the square shaft on the back of the motor and turn it over about 90 degrees. It should reset the brushes and turn it over next time you try.
PostPosted: Mon Jun 17, 2013 10:16 pm
I reckon Starter motor has got stuck in the ring gear. You will hear solenoid click and nothing happens.
Put it in gear and rock the car back and forth by hand. This will free the starter motor from the ring gear.
If this doesn't fix it (I reckon it will)
grab a large screw-driver or something and join the two large terminals on the solenoid - bypassing it. This will tell you if the solenoid is haddit (ie if it don't turn over joining terminals you need a new solenoid)
edit-just realised Mick suggested this as well, (attaching temrinals).
Good luck
Bubba
PostPosted: Tue Jun 18, 2013 6:32 am
Thanks very much. I will have plenty to try after work today. I'll keep you posted.
 Post subject: No Start.
PostPosted: Tue Jun 18, 2013 7:28 am
Check for "Fungus" and weird growths on Battery terminals. Always start checking at the beginning of the power source and see where it stops.
"Let us remove your "SHORTS"
PostPosted: Tue Jun 18, 2013 7:43 am
Davo111 wrote:
Flat battery ;-)
Ill bet a pie on it being a flat battery
I had it where sometimes it would turn over fine and sometimes just "click".
Changed the battery, happy days. :)
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Tue Jun 18, 2013 7:50 am
Thanks but I gave the battery a charge afterwards and terminals are clean. I want to leave work now and try and get it fixed!
PostPosted: Tue Jun 18, 2013 5:09 pm
Problem solved!
Thank you all, the starter motor was stuck.
Car started as soon as we rolled it in gear, gave the starter a whack and some crc.
PostPosted: Tue Jun 18, 2013 5:34 pm
talfox wrote:
Problem solved!
WooHoo I was right :D
PostPosted: Tue Jun 18, 2013 6:36 pm
PDJ wrote:
Davo111 wrote:
Flat battery ;-)
So Bubby, when you getting your pie?? :P
Users browsing this forum: No registered users and 51 guests
