It is currently Sun Jul 27, 2025 9:24 am
 Post subject: Head Gasket
PostPosted: Sun Jun 23, 2013 6:07 pm
Just about to put on my head on to finish my 1275 engine rebuild. Engine has 11.34:1 compression, bit high for my liking for road use.
Was going to use PAYEN BK450 Head Gasket but will compress to .035.
Is there a thicker head gasket or shim, I can use to lower the compression.
From my calculator if I raise the height another,
.040 compression will be 9.67:1
.030 compression will be 9.92:1
.020 compression will be 10.17:1
Assistance would be good
PostPosted: Sun Jun 23, 2013 6:08 pm
just use 2 head gaskets.
PostPosted: Sun Jun 23, 2013 6:59 pm
PM sent, I had replied to your email but it bounced back.
2x BK450 gaskets worked fine for me until I got around to opening the chambers out a bit more.
[edit]
Try a Cometic-
http://www.cometic.com/automotive-gaskets.aspx
[edit 2] Looks like thickest one sold is .040".
http://www.shopengineparts.com/parts.as ... ini+1300cc
 Post subject: head gasket
PostPosted: Mon Jun 24, 2013 7:43 am
As you still have the head out why don't you grind the chambers out a bit larger to increase the volume. Make sure you measure them individually to get them equal. I am not very keen on having two head gaskets especially on that High a compression. It will only need to run a bit lean and blow between 2 and 3 where you have two exhaust valves side by side. Gets pretty hot in that spot.
"Let us remove your "SHORTS"
