Ballast Resistor Bypass
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81903
Author:  syahrr01 [ Tue Jun 25, 2013 1:43 pm ]
Post subject:  Ballast Resistor Bypass
Hi All,
It's getting quite cold this winter and my clubby is getting harder to start in the morning. I'm currently running a GT40R coil with a ballast resistor. Not taking full advantage of this setup as I'm not bypassing the resistor during cranking.
So, how does one correctly wire this bypass to feed the coil the full 12v during cranking?
I'm thinking the red-white wire between the solenoid and ignition will be 12V during cranking. Connecting the + side of the coil to the same terminal on the solenoid should bypass the resistor. When running normally however, doesn't this mean the coil is feeding ~8V to the solenoid? Is that enough to trigger the solenoid to crank the starter motor? Do I need a diode or something?
Author:  drmini in aust [ Tue Jun 25, 2013 2:42 pm ]
Yes that will work, I did it on a motor a while ago, you need a blocking diode in the circuit as said.
Author:  m1100s [ Tue Jun 25, 2013 8:51 pm ]
A diode will induce a voltage drop, best to wire a relay from the start wire switching full battery current or a wire from the output of the start solenoid to the positive coil.
Ash.
Author:  m1100s [ Tue Jun 25, 2013 8:53 pm ]
From the solenoid switching a relay I meant.
Ash.
Author:  1071 S [ Tue Jun 25, 2013 9:11 pm ]
Or just buy a GT40????
But i'm not getting the point....
Cheers, Ian
Author:  drmini in aust [ Tue Jun 25, 2013 9:20 pm ]
Ash.
I didn't find any voltage drop when I did mine. You need to size it big enough.
@syahrr01,
I still have the diode & lead here somewhere (I think I know where), yours for postage if you want it.
I sold the 45D dizzy + electronic module on, replaced it with a Nissan Pulsar one.
Author:  Mick [ Tue Jun 25, 2013 10:16 pm ]
You could change the dizzy out to a higher voltage unit like at the link below. These are rated for your GT40R coil all day everyday, not just at start up.
You get the benefit of a high energy output all day everyday, and a new dizzy. Convertible Mini sells these locally in Oz.
http://www.simonbbc.com/distributors/4c ... h-powermax
Author:  slide [ Wed Jun 26, 2013 6:28 pm ]
I ditched the GT40R and the ballast resistor and fitted a MSD Blaster2 coil with a full 12 volts to it. Noticeable improvement in starting and pick up over the Bosch set up. I got it from here
http://www.ebay.com.au/itm/MSD-8202-Ign ... 23130b7cbb
