ROCKER COVER CLEARANCES
https://www.ausmini.com/forums/viewtopic.php?f=2&t=81930
Author:  MORRIS COOPER S 501 [ Fri Jun 28, 2013 1:50 pm ]
Post subject:  ROCKER COVER CLEARANCES
With Roller Rockers Fitted Can you still run the standard metal type Rocker Cover
or Do you Need to use an Alloy type cover?
Using Either Med engineering or minispares roller rockers?
Author:  drmini in aust [ Fri Jun 28, 2013 2:09 pm ]
Standard tin cover clears Minispares 1.5 and 1.3 rollers OK.
Not sure about the MED ones...
Author:  Lillee [ Fri Jun 28, 2013 2:20 pm ]
I replied to your PM. The standard steel rocker cover that can be purchased from minispares clears the minispares rockers.
Author:  MORRIS COOPER S 501 [ Fri Jun 28, 2013 2:23 pm ]
Yep got it,
MED Clearances 1.5?
Author:  Lillee [ Fri Jun 28, 2013 3:00 pm ]
No idea, never used MED rockers but they look very similar to other rockers.
GR uses Titan roller tips which are very similar to MED and I am sure he fits them under a steel rocker cover.
Author:  mickmini [ Fri Jun 28, 2013 8:08 pm ]
Seems to clear the MED ones on mine.
Author:  sam_1100 [ Sat Jun 29, 2013 9:05 am ]
Lillee and doc, they don't quite fit straight on?
Did you not have to drill out the bolt holes....
Author:  drmini in aust [ Sat Jun 29, 2013 11:18 am ]
Nope, I didn't enlarge the holes, except when putting Corolla rockers under the common Minispares `chinese made' alloy rocker cover.
Author:  sam_1100 [ Sat Jun 29, 2013 1:53 pm ]
Mm fair enough!
I definitely need enlarged holes on the mini spares alloy cover with minisport 1.3s.
Author:  Lillee [ Sat Jun 29, 2013 7:53 pm ]
With minispares roller tip rockers I had to drill them to clear
