Fitting larger fuel tank https://www.ausmini.com/forums/viewtopic.php?f=2&t=81936 |
Page 1 of 2 |
Author: | sam_1100 [ Sat Jun 29, 2013 9:11 am ] |
Post subject: | Fitting larger fuel tank |
I presume any mini can fit either a small tank or a large tank... What will be required to bin my 5.5 gallon and install a 7.5 gallon? |
Author: | raisto2 [ Sat Jun 29, 2013 9:59 am ] |
1x Bin. 1x 5.5 gallon tank. 1x 7.5 gallon tank. ![]() I think they take a different strap? Can't remember off the top of my head. |
Author: | CPOCSM [ Sat Jun 29, 2013 10:06 am ] |
The 7.5 uses the same strap as the5.5 but there is a 10 gallon one as well which uses a diagonal strap across the back of it to stop it moving about. I have one 10 gallon one here but no strap so can't instal it. Will have to make one eventually ![]() Hooroo |
Author: | Panthersteve [ Sat Jun 29, 2013 10:24 am ] |
CPOCSM wrote: but there is a 10 gallon one as well
Hooroo What model used this 10 gallon tank ? |
Author: | raisto2 [ Sat Jun 29, 2013 10:27 am ] |
Panthersteve wrote: CPOCSM wrote: but there is a 10 gallon one as well Hooroo What model used this 10 gallon tank ? That's what I was thinking... ![]() |
Author: | sam_1100 [ Sat Jun 29, 2013 10:32 am ] |
I was thinking the diagonal strap is required for the 7.5 gal? |
raisto2 wrote: 1x Bin.
1x 5.5 gallon tank. 1x 7.5 gallon Almost too easy |
Author: | raisto2 [ Sat Jun 29, 2013 10:39 am ] |
sam_1100 wrote: raisto2 wrote: 1x Bin. 1x 5.5 gallon tank. 1x 7.5 gallon Almost too easy couldn't resist. ![]() |
Author: | MINImal effort [ Sat Jun 29, 2013 10:55 am ] |
The 7.5 gallon tank uses a diagonal strap - there is an extra bracket in the boot for these cars (UK)... However the original 5.5 gallon strap still works with the 7.5... So yep - take one out - put the other in.... |
Author: | Harley [ Sat Jun 29, 2013 10:56 am ] |
Never heard of three tank sizes, only ever known about the imperial 5 and 7.5 gal tanks. A US 10 gal tank s pretty much the same as a UK 7.5 gal tank. Are we sure there's no mix ups? |
Author: | raisto2 [ Sat Jun 29, 2013 11:02 am ] |
Harley wrote: Never heard of three tank sizes, only ever known about the imperial 5 and 7.5 gal tanks.
A US 10 gal tank s pretty much the same as a UK 7.5 gal tank. Are we sure there's no mix ups? 10Gal US = 37.85ltr *7.5Gal Imp = 34.09ltr ~3.75ltr Difference.. My guess is a mix up, or some rare aftermarket/ oddball euro thing. *fixed. |
Author: | drmini in aust [ Sat Jun 29, 2013 11:26 am ] |
You could fit a RH tank instead, either steel, or the aftermarket plastik fantastik one. |
Author: | 1275LS [ Sat Jun 29, 2013 12:50 pm ] |
raisto2 wrote: Harley wrote: Never heard of three tank sizes, only ever known about the imperial 5 and 7.5 gal tanks. A US 10 gal tank s pretty much the same as a UK 7.5 gal tank. Are we sure there's no mix ups? 10Gal US = 37.85ltr 10Gal Imp = 34.09ltr ~3.75ltr Difference.. My guess is a mix up, or some rare aftermarket/ oddball euro thing. I am guessing you mean 7.5 Gal Imp = 34.09ltr. |
Author: | raisto2 [ Sat Jun 29, 2013 12:51 pm ] |
1275LS wrote: raisto2 wrote: Harley wrote: Never heard of three tank sizes, only ever known about the imperial 5 and 7.5 gal tanks. A US 10 gal tank s pretty much the same as a UK 7.5 gal tank. Are we sure there's no mix ups? 10Gal US = 37.85ltr 10Gal Imp = 34.09ltr ~3.75ltr Difference.. My guess is a mix up, or some rare aftermarket/ oddball euro thing. I am guessing you mean 7.5 Gal Imp = 34.09ltr. SSSssssssshhhhh!!!! ![]() |
Author: | CPOCSM [ Sat Jun 29, 2013 1:18 pm ] |
Got the two side by side and one is bigger than the other. Bought it at a swap meet in goulburn many moons ago and has a relief in the bottom to fit over the battery cover. It may have had a patch put in it but I am not stripping the paint to check. ![]() Just bought a plastic RH tank on fleabay so will have to punch a hole in the other side to fit. Does anyone have a definitive way to make the template for drilling a hole? Hooroo |
