Camshaft ID? https://www.ausmini.com/forums/viewtopic.php?f=2&t=81959 |
Author: | Kennomini [ Mon Jul 01, 2013 5:30 pm ] |
Post subject: | Camshaft ID? |
How can I identify camshafts? What numbers should I be looking for and any other obvious things that help tell them apart (eg say a 998 cam from a mk1 S cam)? |
Author: | TK [ Mon Jul 01, 2013 6:42 pm ] |
Numbers, lobe size (width), drive, number of rings. Grab a Vizard book. It will help identify factory cams. |
Author: | TheMiniMan [ Mon Jul 01, 2013 7:29 pm ] |
small-bore cams are normally narrow lobes (3/8"ths) & pin-drive-->, except the Late A+ 998 which are slot/spade drive 1100"S" cams are all wide lobe 1/2" & are spider drive Cooper"S" are wide lobe & pin-drive Late 1275 A+ are all spade-drive wide lobes ............................................................................. If you are planning on finding a suitable cam for your twinky to grind all the lobes off, then maybe a spade drive cam as they`re easier to find,,, easy to get oil pumps to suit,,, & also fit the block you`re using too ![]() |
Author: | drmini in aust [ Mon Jul 01, 2013 7:38 pm ] |
If you find any narrow lobe spider drive cams, they came out of a 998 auto or 1098 auto. |
Author: | dodge [ Mon Jul 01, 2013 7:45 pm ] |
cooper s cams dont have the fuel pump lobe , well mine didnt |
Author: | low n blown [ Tue Jul 02, 2013 8:34 am ] |
David Vizard's book "tuning the A series engine" has an excellent table for identifying factory camshafts including the performance cams available from the factory. |
Author: | Convertible Mini [ Wed Jul 03, 2013 10:19 am ] |
Post subject: | Cam shafts. |
I have always wondered about a particular Cam shaft that I have which is spider drive type and 3/8 lobe. What would it's origin be? |
Author: | drmini in aust [ Wed Jul 03, 2013 11:36 am ] |
Post subject: | Re: Cam shafts. |
Convertible Mini wrote: I have always wondered about a particular Cam shaft that I have which is spider drive type and 3/8 lobe. What would it's origin be?
Automatic 998 mini or auto Morris 1100 (1098) for sure. The autos all got spider drive until 1980 because of their HUGE oil pump. A pin drive would shear off driving that pump. I have no idea what the Rover automatics have from 1980 on, whether still spider drive or they went to slot drive. |
Author: | Convertible Mini [ Wed Jul 03, 2013 5:02 pm ] |
Post subject: | Hmm! |
Thanks Kev Now I know what it is from. |
