It is currently Mon Jun 23, 2025 12:50 pm
 Post subject: Start you mongrel.
PostPosted: Wed Jul 03, 2013 9:09 pm
Well it's got me.
The moke has decided not to play the game.
It has fuel, it has spark and it's now on the charger again because it just wont start.
What else should I be checking?
Am I missing something obvious?
Image Image
PostPosted: Wed Jul 03, 2013 9:13 pm
will it fire with some startyabastard?
if so, drain the tank & carb and put fresh fuel in it
PostPosted: Wed Jul 03, 2013 9:30 pm
Yeah Simon, I should have said, it'll fire with Aerostart but only for a sec.
So you thinkin just crappy fuel?
Image Image
PostPosted: Wed Jul 03, 2013 9:36 pm
Stale fuel perhaps rather than crappy, particularly if you ran it on a higher octane like 98?
KB
PostPosted: Wed Jul 03, 2013 9:43 pm
You've got me thinking now. I think I might have filled up with 98 last time.
The tanks nearly empty anyway so I'll dump it and give it a fresh lot tomorrow.
Image Image
PostPosted: Wed Jul 03, 2013 10:14 pm
How confident are you that it's getting enough fuel? Could be a blocked jet.
Fresh fuel, and fresh plugs will work wonders.
PostPosted: Wed Jul 03, 2013 10:25 pm
Fuel is getting to carb and plugs are getting wet. Plugs have strong spark.
It's always been hard to cold start and has a tendency to over run when shutting off. Could the timing be out??
Image Image
PostPosted: Thu Jul 04, 2013 4:30 pm
maybe a little bit too advanced, but try fresh fuel... it's easier than taking the carb apart
PostPosted: Thu Jul 04, 2013 11:44 pm
Is it a good strong spark from the coil lead, at the H/T leads & through each of the spark plugs? If spark weak, try a different coil.
If s/plugs to wet, there my be excess fuel sitting on top of the pistons, remove s/plugs, block fuel line & crank. Clean fuel from s/plugs with carb cleaner or try & heat them slightly with a lighter or butane torch. Otherwise try new plugs (maybe slightly hotter ones).
As Simon said try new fuel if been sitting for a while. (if su carb) Drain old fuel out of the fuel bowl & put new stuff in, then put rest in tank.
PostPosted: Fri Jul 05, 2013 7:49 pm
My K does the same thing every so often plenty of fuel and spark but will wet the plugs. have a look under the carb to see if the jet has returned fully after using the choke. on mine it was sticking down after the choke had been pushed back in. worth a look
66 Van 1275
69 K Sedan
69 K Van Teabag
66 austin Countryman
68van
PostPosted: Fri Jul 05, 2013 11:12 pm
So I changed the plugs and drained the fuel and managed to fire it up.
I couldn't give it to much throttle at first as it would brake down but seemed ok when it warmed up.
I decided to drive to the servo for a top up but as I pulled into there (3min later) it sounded like it dropped onto one cylinder. I managed to drive it home very slowly as it was braking down really bad. I probably should have pushed it home, it's not that far.
I found that with the motor running I can pull either lead off the centre two plugs with minimal effect to it running. Pull either of the outer leads and there is a very noticeable difference.
All plugs have good spark.
I'll check the compression tomorrow I think and give a different coil a go.
Image Image
PostPosted: Sat Jul 06, 2013 11:35 am
Try swaping and ignition lead from an outside to a central one
Could be just leads, also check your rotor cap
PostPosted: Sat Jul 06, 2013 12:26 pm
Put a meter on all the leads you cannot tell condition by looking at them.
If they measure over 5K ohm they are shagged, go buy some new ones.
Users browsing this forum: Bing [Bot] and 83 guests
