re-spacing rollertip rockers for a 1098?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82001
Author:  mattsmadmini [ Fri Jul 05, 2013 6:23 pm ]
Post subject:  re-spacing rollertip rockers for a 1098?
Has anyone done it?
http://www.minisport.com.au/prod1916.htm
Is that kit needed?
I have a set of 1.3 rollertip rockers from Mini****t and only realised as i was setting clearances how "out" a few of the tips are...
Just the tips... :lol:
Author:  drmini in aust [ Fri Jul 05, 2013 7:14 pm ]
If the rollers do not cover the valve stems, the rockers need shimming or mods to move them. This `should' only be needed on exhausts, because the exhaust valve positions were moved on 1275 heads compared to smallbore heads (to fit the bigger valves in).
Some makers supply a different set for smallbores only...
I have also noticed that rollers can beat up the tops of the valves compared to regular rockers. Danny's inlet valves (almost new) were particularly bad, they had a radius worn into the end. But the rollers on the 1.3 rockers were still fine.
Author:  sam_1100 [ Fri Jul 05, 2013 11:02 pm ]
Chong bolted His Minisport 1.3s straight onto mine?
Author:  drmini in aust [ Fri Jul 05, 2013 11:11 pm ]
Pull the rocker cover and look in from the front. The rollers don't have to be dead central on the valve stem but they should cover it.
