Steering rack U bolts, plastic bush??needed?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82008
Author:  haze blue 850 [ Sat Jul 06, 2013 4:37 pm ]
Post subject:  Steering rack U bolts, plastic bush??needed?
Greetings All.
About to fit steering rack. Lost, but found the second special U bolt. Ha!
Never saw but was told there's a plastic band/saddle that slips in between the U bolt and rack.
Is this important .Can it be a bit of rubber or plastic containers??
Alex.
Author:  TheMiniMan [ Sat Jul 06, 2013 6:01 pm ]
the later minis had 2 metal straps (one on each u-bolt) to help support the u-bolts,,, (an attempt to help stop the u-bolts bending)
otherwise there is a felt-seal that goes over the pinion before fitting the rack to help seal the hole through the floor
but that`s about it on our Aussie cars
Author:  drmini in aust [ Sat Jul 06, 2013 6:57 pm ]
I dunno if you can still buy that felt seal, but a bit of closed cell 1/4" thick plastic foam works fine.
Author:  miniDave [ Sat Jul 06, 2013 6:58 pm ]
^^^^^^^^^^ditto
Author:  TheMiniMan [ Sat Jul 06, 2013 7:35 pm ]
i use pieces cut out of an old thong
no,,, not that sort of thong :-)
the type you wear on your feet
Author:  haze blue 850 [ Sat Jul 06, 2013 8:28 pm ]
Thanks All.
Got it all in. Looks great.
I used a thin strip of rubber (just to stop it chaffing.)
For the spline gizmo I cut a seal out of some bitumised foam, (Stuff you use for roof sheeting back channels)
Thanks again.
Alex.
Author:  Kennomini [ Sat Jul 06, 2013 9:13 pm ]
Aaaahhhhhhhh so that explains why you only have one thong;
:lol: :lol: :lol: (That is you isn't in Matt?)
