Gearbox build?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82013
Author:  Kennomini [ Sat Jul 06, 2013 10:40 pm ]
Post subject:  Gearbox build?
I have a four syncro remote gearbox housing, and gear set. It has a couple of damaged gears (snapped off teeth) on the laygear and on the 2nd or 3rd gear. Anyway can I fit a complete gear set from a four syncro rod change gearbox into the remote housing?
Are parts (gears) interchangeable?
Author:  drmini in aust [ Sat Jul 06, 2013 10:45 pm ]
All will fit, except reverse. It has the same tooth count but the fork slot is in a different place, so use your old one.
Author:  Kennomini [ Sat Jul 06, 2013 11:35 pm ]
That's good news.
Where from and what brands are best for box bearings and thrust washers etc?
Author:  drmini in aust [ Sun Jul 07, 2013 8:44 am ]
Kennomini wrote:
That's good news.
If you want all the gearbox bearings Karcraft does a kit, with or without the 2 diff ones. It saves you a few bucks.
Likewise they have the copper and (correct thickness) fibre washers for the diff.
Author:  Kennomini [ Sun Jul 07, 2013 8:44 pm ]
I'm fitting a Quafie 36K ATB diff (pot joints), what diff bushes etc do I need?
Author:  drmini in aust [ Sun Jul 07, 2013 8:48 pm ]
None internally.
But the 2 side cover bushes are probably worn as usual, I would fit new ones.
Note these need machining to size after press fitting- boring them in a lathe is the best method, IMO.
