mk 1 cooper s interior https://www.ausmini.com/forums/viewtopic.php?f=2&t=82022 |
Author: | carter [ Sun Jul 07, 2013 4:58 pm ] |
Post subject: | mk 1 cooper s interior |
hello all! just wandering what type of door cards a mk 1 had compared to a mk 2? also is the pattern in the duluxe on the seats etc the same as an s thanks in advance. |
Author: | brett [ Sun Jul 07, 2013 5:29 pm ] |
what year is it? there were 2 mk1 different designs |
Author: | carter [ Sun Jul 07, 2013 5:41 pm ] |
G'day Brett! Thanks for your reply it is a 67 model number 3273 lake green same colour as yours...... I have a set of door cards that have the pressed in rectangle thing two of them.... If these are not to my car what did they come out of ? |
Author: | brett [ Sun Jul 07, 2013 5:48 pm ] |
I am sure your car should have the same trim as mine. Straight lines.. I am actually selling mine.newton commercial aussie trim as the grain and colour.was slightly wrong. |
Author: | carter [ Sun Jul 07, 2013 5:53 pm ] |
I already have started gathering some interior... Have got the vynal for both front and back seats but only have the backs of seats still after the bases, have pocket cover things and thought I had door cards.... Maybe someone else can fill me in or confirm what your saying brett |
Author: | brett [ Sun Jul 07, 2013 6:46 pm ] |
http://www.ausmini.com/forums/viewtopic.php?t=78059 http://www.ausmini.com/forums/viewtopic.php?t=73877 http://www.ausmini.com/forums/viewtopic.php?t=73881 upto sometime in 67 then they changed over to http://www.ausmini.com/forums/viewtopic ... 72cfef3e94 |
Author: | brett [ Sun Jul 07, 2013 6:47 pm ] |
carter wrote: G'day Brett! Thanks for your reply it is a 67 model number 3273 lake green same colour as yours...... I have a set of door cards that have the pressed in rectangle thing two of them.... If these are not to my car what did they come out of ?
Yours could be correct door cards.. eitherway keep them |
Author: | carter [ Sun Jul 07, 2013 7:06 pm ] |
ok thank you brett I think I have the right door cards.... not so sure about the pattern on the vynal ... I have the backs of all three chairs is the pattern the same from the change over in seats only the base stops? does anyone have some photos of these... thanks for all your help so far brett. |
Author: | brett [ Sun Jul 07, 2013 7:42 pm ] |
what do you mean by patern? as in the grain? or the style of the cut? Have a look at the Deluxe and that will be what you need to do to be correct |
Author: | carter [ Sun Jul 07, 2013 7:47 pm ] |
I mean the profile of the vynal not the grain. The pattern stops on the base of the seats where as with your mini and mk 2s the stripes continue over and down the front of the seats. Is the profile the same on the back except the base is the only difference ? |
Author: | phillb [ Sun Jul 07, 2013 8:46 pm ] |
Copied from an old post re this.... marc2131 wrote: There isnt much info on the type of seats used in Australian minis.
The UK minis used different seats, notice the Australian ones tended to be fluted stictched type seats. Here are photos of what I believe are the original rear seats from my 66 Deluxe. The front seats have since dissapeared. ![]() ![]() Am not sure which type of front seats it goes with. Could it be with this: 1. BMC stitched fluted design seats http://www.newtoncomm.co.uk/cars/mini/p ... =19&type=1 2. or the ones above in Philb's red interiored Mini. Would appreciate some clarification. Want to get my restoration correct. Thanks in advance to all the advice to date (Phil, Michael etc) Marc I'm no expert and I'm sure someone will correct me if I'm wrong but as far as I know there were 3 patterns in the Aussie roundnoses. 1964 - 1967 Whick looks like your rear seat which I would say is the correct one for your car. It has the set of evenly spaced pleats and the squab at the front edge. The fronts follow the same pattern. Like this.. ![]() ![]() and this... ![]() Actually this Blue Deluxe is on Carsales and same year as yours and looks pretty orig so worth a look as a guide.) 1967 - 1969 Is the next pattern which you see in my car It has pleats but the 2 outer pleats are wider and all pleats continue over the front edge of the seat. Note also that the door trim pattern changed but I'm not sure if that was at the same time as the seats. ![]() ![]() 1969 - 1971 Last pattern seen in most Mk2 minis is similar but less pleats having one wider pleat in the centre. ![]() Also the pattern in the vinyl. Your vinyl might have a pattern like this if its original but I;m not sure if they were still using the same vinyl over those years. ![]() |
Author: | carter [ Sun Jul 07, 2013 9:01 pm ] |
ok thank you every body for all your help really appreciate it ![]() |
Author: | John Smidt [ Sun Jul 07, 2013 9:07 pm ] |
Note, The pattern on the door trims how they change in the photos, and they are correct |
Author: | carter [ Sun Jul 07, 2013 9:16 pm ] |
ok thanks a lot john ! you knowledge and wisdom is always welcome ![]() |
